Old 09-10-2022, 10:25 AM   #1
larry butcher
Default removing pan from '48 Merc engine
Can't remove pan from '48Merc. engine which is in '40 Ford STD.2 dr. In side of pan is hanging up on flywheel , not crank counterweights.
larry butcher is offline   Reply With Quote
Old 09-10-2022, 10:57 AM   #2
Flathead
Flathead's Avatar
Default Re: removing pan from '48 Merc engine
Can you move the pan around at all?
Flathead is offline   Reply With Quote
Old 09-10-2022, 03:08 PM   #3
corvette8n
corvette8n's Avatar
When I worked on my ‘50 Ford, I had to remove the nut on the front motor mounts and jack up the motor in order to remove the pan.
Old 09-10-2022, 06:14 PM   #4
42merc
42merc's Avatar
Have you removed the bolt that is installed from the top at the right rear of the pan ?
42merc is offline   Reply With Quote
Old 09-10-2022, 07:26 PM   #5
larry butcher
Thanks for all of your replys, will pass on top the owner
Old 09-10-2022, 07:42 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Pictures BELOW show where this bolt is threaded into pan from TOP side, just above starter Bendix.
Coop
Click Links Below __
T5 W/TORQUE TUBE
