Old 12-11-2018, 12:26 AM   #21
Synchro909
Synchro909's Avatar
Default Re: Rear Axle removal to inspect gears
Originally Posted by Rich in Tucson View Post
Just remember with old Ford Banjo rear ends, and ONLY old Ford rear ends, "Left is right, and right is wrong".
Is that right?
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 12-11-2018, 10:27 AM   #22
Purdy Swoft
Purdy Swoft's Avatar
Both axles are the same and will work on either side .
Old 12-11-2018, 10:33 PM   #23
Paul Bjarnason
I think that since so many Model A rear ends have spun bearings, probably due to incorrect pre-load setting on the axles, it would be wise to disregard the gaskets installed and to set up the bearing pre-load fresh, on the axles.
Paul Bjarnason is offline   Reply With Quote
Old 12-12-2018, 12:47 PM   #24
40 Deluxe
I think that would depend on whether the bearings in his axle are spun. If not, remember: "If it's not broken, don't fix it!".
Old 12-12-2018, 07:04 PM   #25
redmodelt
redmodelt's Avatar
You also need to inspect the outer hub races, the wear is on the bottom.
Old 12-12-2018, 07:41 PM   #26
Paul Bjarnason
OK, but even if it's not broke - what if I could make it just a little bit better - you know, just tinker a bit?! I have trouble leaving anything alone! LOL
Seriously, in thinking over my advice to check the pre-load on the axle bearings, it later dawned on me that this particular project was being done with the axle in the car, which means that the drive shaft would not have been removed. Without removal of the drive shaft, the axle pre-load cannot be checked, since you cannot spin the axles to measure the drag to the recommended 20 inch pound spec.
