Old 10-06-2015, 07:02 PM   #1
Fillinjc
Fillinjc's Avatar
Default Front Transmission Bearing Retainer
Hi,
Pulling apart the transmission in my 1930 coupe in order to do some troubleshooting. Following Les Andrews Vol 1 shows the front bearing retainer under the bell housing. Mine appears to be one with the bell housing. Is this not a standard Ford part?
Just curious.
Thanks,
Jerry
Fillinjc is offline   Reply With Quote
Old 10-06-2015, 07:15 PM   #2
bdave_mcc
bdave_mcc's Avatar
Default Re: Front Transmission Bearing Retainer
Give it a tap or two, that thing should have stayed with the transmission. Probably just stuck in there good. The retainer isn't actually under the bellhousing, the bellhousing fits around in like yours is.
bdave_mcc is offline   Reply With Quote
