Old 11-23-2019, 06:32 PM   #1
Ian1932
Ian1932's Avatar
Default Cutting Holes in Frame Webbing
Not sure how this is supposed to be done but i found if you take a hole punch 1/16" smaller that the hole you need to cut. Put it in a hand drill. Wet the webbing with a spray bottle and water. The punch will center itself in the hole. With little pressure it will cut a perfect hole. Because its smaller than the hole, it wont touch the frame and mess up your paint, it will spin on the 1/32 of webbing. The bolts still push right through. Thought i would share...
Ian1932 is offline   Reply With Quote
Old 11-23-2019, 07:38 PM   #2
RalphM
RalphM's Avatar
Default Re: Cutting Holes in Frame Webbing
I’ve got a set of MAC hole punches that do a perfect job of that. Just have to back it up with some hard wood and the hole comes out clean.
RalphM is offline   Reply With Quote
Old 11-23-2019, 08:59 PM   #3
woodiewagon46
I found that backing the webbing with wood or some other material makes a clean cut. Believe it or not I have been using a 1/4" foot square of lead and allowe's the punch to cut right through.
woodiewagon46 is offline   Reply With Quote
Old 11-23-2019, 09:02 PM   #4
Gary Tosel
Gary Tosel's Avatar
I have found that using a hole punch on hardwood is a good idea and I always use the end grain that allows the punch to cut a very clean hole.
Gary Tosel is offline   Reply With Quote
Old 11-23-2019, 09:24 PM   #5
Elmo Rodge
Elmo Rodge's Avatar
I believe Ian is talking about doing it right on the frame rail thus perfectly locating the holes. Cool idea.
Wayno
Life is not a spectator sport.
Elmo Rodge is offline   Reply With Quote
Old 11-23-2019, 10:39 PM   #6
Ian1932
Ian1932's Avatar
Wayno
Yes! You double face it to the frame and just find the holes underneath. Then, just put the punch in a drill over the hole and a few spins and it just cuts a perfect in exactly the spot you want it! If you wet it with water first it works even better. The holes i just cut in the pic, the webbing was already in place! If you make sure to use a punch 1/16" in DIA smaller than the hole it wont scratch the frame, it leaves a cushion of fabric around the perimeter...just a 1/32 so you can still push your bolt through....
Old 11-24-2019, 10:35 AM   #7
deuce_roadster
deuce_roadster's Avatar
I put the webbing on the frame with a few plastic spring clamps, mark the holes from the underside with a sharpie then using a maple (hardwood) piece of wood like others have said and punch them all off the frame. Never had any misalignment of holes or "messed up paint". From the factory I have seen brass grommets in the bolt holes that held the webbing on the frame during its trip down the assembly line.
Old 11-24-2019, 12:14 PM   #8
Viv W
I have put the webbing on the frame, then using a tapered pin punch, first push the tip thru the webbing into the hole in the frame, then a sharp tap with a hammer on the punch, it cuts a neat hole in the webbing.
If you put a bolt thru the webbing and the hole in the frame, it keeps the webbing in place for the next hole to be done. It worked a treat with no paint damage.
Viv W is offline   Reply With Quote
Old 11-24-2019, 09:54 PM   #9
DavidG
DavidG's Avatar
I do as Mike does.
