Old 07-05-2018, 10:20 AM   #1
thespoiler
thespoiler's Avatar
Default Carburetor identify
I received 2 extra carburetors with my Model A....neither one has a brand name..The one on the left has "model XF" the other has "Made in the USA"...
Can anybody help me identify the carbs?...thanks in advance
"Half the people you meet are below average".
thespoiler is offline   Reply With Quote
Old 07-05-2018, 10:50 AM   #2
1930artdeco
1930artdeco's Avatar
Default Re: Carburetor identify
Left is a Tillotson, Right is a Marvel/Allstate.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 07-05-2018, 11:24 AM   #3
160B
160B's Avatar
The one on the right is a Marvel Schebler
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 07-05-2018, 12:34 PM   #4
thespoiler
thespoiler's Avatar
Thanks...both look pretty good...is one considered better. And which would it pay to have rebuilt?
Old 07-05-2018, 03:46 PM   #5
1930artdeco
I have not used a Tilly, the Marvel I loved when I could get it to run.
Mike
1957 Country Sedan
Old 07-05-2018, 06:26 PM   #6
loubob
The Marvel by far.
Dave Renner @ Renners Corner does excellent work and has all the correct parts.
734-428-8424.
loubob is offline   Reply With Quote
Old 07-06-2018, 05:08 AM   #7
PRG999
I like the marvel. You may not need to rebuild it. Bolt it on and run it.you may have one in good shape. the fuel line is different for the marvel then the zenieth. The lenght of the carb is shorter so the stock line wont line up. To try different carbs i made a fuel line by cutting the middle section out of an old line and added rubber fuel line . This lets me swap carbs out to test different ones. And not worry about if the lines match up to the carbs.
PRG999 is offline   Reply With Quote
Old 07-06-2018, 05:34 AM   #8
Patrick L.
Patrick L.'s Avatar
As long as the Tillotson is not warped[which can usually be fixed] then both are good carburetors. The Marvel I think tends to run better though. Both are simple and easy to clean/rebuild.
Old 07-06-2018, 10:25 AM   #9
abachman3
abachman3's Avatar
A group of us in the local club here all run the Marvel and like them. They seem to give a tad more high end performance, running better at 50-60 mph.
abachman3 is offline   Reply With Quote
Old 07-06-2018, 11:06 AM   #10
Synchro909
Synchro909's Avatar
Not to sidetrack this thread but which is the better, a marvel or the Zenith from a B engine which Has been pressure balanced?
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 07-06-2018, 11:19 AM   #11
JBill
I didn't have any problem with it lining up with the fuel line, but my Marvel takes a different size (smaller) coupling between the carb and the fuel line. I had one all made up so I could use the Marvel/Schebler once in awhile, but danged if I can find it now.
JBill is offline   Reply With Quote
Old 07-06-2018, 12:02 PM   #12
1930artdeco
On my line I just bent it between which carb I was using. but I also have a spare line just incase It develops a crack. Renners has the fitting that goes into the Marvel that is a special size.
Mike
1957 Country Sedan
