Old 07-01-2015, 03:42 PM   #1
bikemaniac
Smile Install exhaust manifold without gland rings?
Hi,
My newly welded exhaust manifold showed a new crack after 50 mi of driving and therefore I bought myself a new one.
1. Is it true you can install the manifold without the gland rings as they are basically not necessary for proper function?
2. It it necessary to apply a high temp gasket sealant (like high temp RTV) on both sides of the conventional gaskets?
3. Is the muffler bolted directly to the manifold or do people add some high temp sealant there too? I was told that there is basically no space for any seals at all in that area. Presently I have no seals, gasket or high temp sealant where the two are bolted together by means of the bracket.
Lucas
bikemaniac is offline   Reply With Quote
Old 07-01-2015, 03:58 PM   #2
Mitch//pa
Default Re: Install exhaust manifold without gland rings?
1. i use gland rings whenever possible
2. i use copper gaskets and no sealer
3. i use a new clamp with the little insert tube in the pipe no sealer
4. other opinions vary
5. like dad uses sealer
6. etc etc
7. never had a leak and dont like using messy ugly sealer when its not needed
8. SA son
Old 07-01-2015, 04:01 PM   #3
bosstime2
bosstime2's Avatar
I do the same as Mitch
1929 Open Cab Pickup
1930 Standard Roadster
1936 Buick Special Trunk Back Sedan
bosstime2 is offline   Reply With Quote
Old 07-01-2015, 04:32 PM   #4
29 model-a
29 model-a's Avatar
X2 for me also
29 model-a is offline   Reply With Quote
Old 07-01-2015, 05:09 PM   #5
mlp623
mlp623's Avatar
I have done the same with good results Below are some pictures of the progress. I did use cement on the exhaust - see the video here -> https://www.youtube.com/watch?v=yO6yV0ZUITo
mlp623 is offline   Reply With Quote
