Old 07-05-2020, 02:21 PM   #1
KenBolton
Default Pickup Leg Room Needed
I am six three, 220 lbs and 67 years young. I have shortened the brake and clutch peddles by 3/4” but still have a challenge getting into my 82-B with no seat installed. Touring Standards don’t like foam on plywood. What other options are available? Would the Snyder minus two inch springs make enough of a difference?
KenBolton is offline   Reply With Quote
Old 07-05-2020, 05:20 PM   #2
ed thibodeau
Default Re: Pickup Leg Room Needed
On my 31 I removed the seat back spring and put in a piece of 1/4 plywood
with a piece of one inch foam rubber and tacked the upholstery to the plywood
this gave me an additional 3 1/2 inches. And I changed the forward stop blocks
on the seat bottom and moved it back.
ed thibodeau is offline   Reply With Quote
Old 07-06-2020, 11:35 AM   #3
PRG999
On my pickup, i also removed the seat back as above. I also took the seat springs and compressed them about an inch or so and held with zip ties. I would some day like to try the suppliers lower seat springs. The zip tied springs sometimes get a bit to hard to sit on.
I have to admit with those two changes theres a whole lot of room in the cab now.
PRG999 is offline   Reply With Quote
Old 07-06-2020, 12:02 PM   #4
woofa.express
woofa.express's Avatar
On my ute I pushed the seat rearwards to the bulk head and that allowed me to cut the seat frame back about 3 inches. I then replaced the seat back with ply covered with a thin piece of foam. Still not easy but never the less much better to enter and climb out. On my tourer I removed the rear row of seat springs and that allowed me to cut about 5 or 6 inches off the seat frame. I still may replace the seat back springs with a piece of foam. The front is cramped but there is enough room in the back seat to carry 15 sheep and 3 dogs.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is online now   Reply With Quote
Old 07-06-2020, 12:47 PM   #5
30 Closed Cab PU
At 6 ft 230 lbs, I find that getting in and out of my late 30 Closed cab takes a method, but OK. I use a towel or blanket on the seat so I can slide/turn a lot easier getting in and out. At 6 ft 3 not exactly your issue, but maybe will help.
Old 07-07-2020, 10:25 AM   #6
Brentwood Bob
Woofa, your dogs must be smallish.
Brentwood Bob is online now   Reply With Quote
Old 07-07-2020, 07:02 PM   #7
woofa.express
I'll weigh him (it) and post a picture for you Brentwood Bob. It's (got squeeky bark) a working dog and not permitted in house or motor cars with exception of the A ute and Toyota ute.
I know many things,
Old 07-07-2020, 07:18 PM   #8
Synchro909
Synchro909's Avatar
There was a company here that produced cabs for P/Us with an extension built into them. I don't remember how much they extended the cab but it doesn't matter - they don't do it now. I believe there wasn't the market for them.
Old 07-09-2020, 03:14 AM   #9
woofa.express
https://www.youtube.com/watch?v=txiR7oEVGd0
that should amuse you Bob. the main star looks like a Kelpie X Blue Healer. I'll check YouTube for a kelpie running across the sheep. cheers, gary
I know many things,
Old 07-09-2020, 09:55 AM   #10
bosstime2
bosstime2's Avatar
Best thing I did: from the passenger side heat up the bottom of the shift lever with a torch until it’s red hot and slowly pull the shift knob towards the passenger side. A slight bend will do wonders for leg room
1929 Open Cab Pickup
1930 Standard Roadster
1936 Buick Special Trunk Back Sedan
bosstime2 is offline   Reply With Quote
Old 07-09-2020, 10:09 AM   #11
Ray in La Mesa
Brookville Roadster makes an extended open cab for the A pickup but they lengthened the cab in the rear 1/4 panel behind the door, not the door. If they lengthened it in the door it would be easier to enter & exit.
Ray in La Mesa is offline   Reply With Quote
Old 07-09-2020, 11:49 AM   #12
KenBolton
Yup, I bent the shifter to the right too. Thanks for all the input!
Old 07-09-2020, 04:35 PM   #13
woofa.express
No. Not if you are in Aus.
I know many things,
