Old 07-01-2018, 06:51 AM   #1
40Pickup
40Pickup's Avatar
Default A engine fitted with B fuel pump bracket ?.......
Old fire pump.
Looks like someone tried installed bracket for B fuel pump.
Has anyone seen this before?
Thanks, Jorgen
40Pickup is offline   Reply With Quote
Old 07-01-2018, 09:11 AM   #2
d.j. moordigian
d.j. moordigian's Avatar
Default Re: A engine fitted with B fuel pump bracket ?.......
Now THAT'S interesting,......is the "pad" for the fuel pump cast on the block?
OR was it a hole that some one tried to make do...?
d.j. moordigian is offline   Reply With Quote
Old 07-01-2018, 10:19 AM   #3
40Pickup
40Pickup's Avatar
The owner is a friend so I only have the picture.
What I can see in the picture is not cast together with the block, so not part of the block.
If you zoom the image, it appears that the "pad" is attached with 4 screws.
The cylinder head is from a B engine.
Jorgen
Old 07-01-2018, 11:19 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Could it be some "Industrial" block????
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-01-2018, 12:17 PM   #5
Keith True
Keith True's Avatar
It would be interesting to know if it is cast in,or if it is just a patch where a rod came through the side.
Keith True is online now   Reply With Quote
Old 07-01-2018, 01:06 PM   #6
Flathead
Flathead's Avatar
There is a lot of weird stuff going on in that picture.
Flathead is offline   Reply With Quote
Old 07-01-2018, 02:23 PM   #7
J Franklin
J Franklin's Avatar
retracted idea it was repair
Old 07-01-2018, 02:32 PM   #8
40 Deluxe
Do you have any more pictures? Is this engine running a welder? Air compressor? Generator? Buzzsaw? It must have been used in wintertime, what with the priming cup added on.
40 Deluxe is online now   Reply With Quote
Old 07-01-2018, 03:28 PM   #9
Bob C
This one is near the back of the block.
Bob
Old 07-01-2018, 03:28 PM   #10
40Pickup
40Pickup's Avatar
Water pump for fire extinguisher.
Well, I need to see it in person so I can answer your questions better and with more pictures.
Thanks, Jorgen
Old 07-01-2018, 05:40 PM   #11
40 Deluxe
Thanks, Jorgen
Interesting! Looks like it used some of the water it was pumping for cooling, don't see a radiator.
Old 07-01-2018, 11:46 PM   #12
40Pickup
40Pickup's Avatar
Bob
Thank you for the picture!
What is the story of this one?
Jorgen
