Old 05-03-2017, 09:50 AM   #1
pjjbmax
Default Model A & AA radiator shell the same?
Does anyone know if the A & AA radiator shells are the same?
pjjbmax is offline   Reply With Quote
Old 05-03-2017, 09:55 AM   #2
Tiny
Tiny's Avatar
Default Re: Model A & AA radiator shell the same?
The simple answer is no.
28-29 is the same shape but painted black not chrome.
30-31 is a painted shell with no widows peak at the top of the radiator it just goes straight across from side to side
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 05-03-2017, 10:08 AM   #3
100IH
Plus deeper from front to rear. AA has a thicker core because of more rows of tubes. Also 30 &31 shells are not stainless except for the uncommon deluxe models
100IH is offline   Reply With Quote
Old 05-03-2017, 10:30 AM   #4
pjjbmax
Thanks.
So I need a shell for my 28 AA. If I get a 28/29 Model A shell it would work?
Old 05-03-2017, 10:34 AM   #5
SeaSlugs
SeaSlugs's Avatar
Originally Posted by pjjbmax View Post
Thanks.
Yes - factory it would have been painted black plain steel but the stainless car one will fit perfectly.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-04-2017, 12:33 AM   #6
Chris Haynes
Chris Haynes's Avatar
I have never seen a '28/'29 that was stainless.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 05-04-2017, 07:18 AM   #7
Brian SATX
Brian SATX's Avatar
Here is a picture of the 30-31 shell
Brian SATX
Brian SATX is offline   Reply With Quote
Old 05-04-2017, 01:55 PM   #8
1928Mik
1928Mik's Avatar
I MIGHT have a 28-29 AA shell. I will look next time I go over to the garage where I have my A and all parts stored. Might be a week or so......I'll let you know.
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 05-04-2017, 04:51 PM   #9
CHuDWah
CHuDWah's Avatar
Maybe it's my monitor but is the background on that badge red
CHuDWah is offline   Reply With Quote
Old 05-04-2017, 06:45 PM   #10
SeaSlugs
SeaSlugs's Avatar
Im wondering if it was only offered on ambulances/firetrucks/funeral hursts like the 30/31's which over the years since they were identical to 28/29 cars so if it was removed or installed noone will know how it left the factory...
Old 05-04-2017, 07:22 PM   #11
Gunmetal blue2
Gunmetal blue2's Avatar
my 29 town sedan had a stainless steal rad. shell.
Gunmetal blue2 is offline   Reply With Quote
Old 05-04-2017, 09:58 PM   #12
SteveB31
SteveB31's Avatar
Early 1928 cars and AA trucks had a radiator shell with a wrap thru welting (no rivets). Cars were nickel plated, pickups and AA trucks were black painted. Later 1928 radiator shells had riveted welding and the finish was the same. Both of these shells were round under the crank hole cover. 1929 Radiator shells were nearly identical, only the area under the crank hole cover was bell shaped. Still black on commercial vehicles, and nickel on most passenger cars, chrome on Town Cars and some later 1929 cars. In 1930 the radiator was taller, and the grille shells on passenger cars were stainless steel. Pickups and smaller (not AA) commercial vehicles had a steel grille shell paint black. AA trucks had a steel grille shell painted black that was much thicker due to the thicker AA radiator, and it was flat under the emblem ( not peaked). All of these grilles had a blue Ford emblem (in the USA). In 1931 the stainless passenger car shells had the painted recess in the upper portion of the shells, with a stainless emblem. Small commercial vehicles (not AA) had the same steel shell as in 1930 , but with a stainless emblem. AA trucks had the same thicker flat steel shell with a stainless emblem. Ambulances and hearses and a handful of deluxe AA trucks had the same radiator shell , only stainless steel.
SteveB31 is offline   Reply With Quote
Old 05-04-2017, 10:02 PM   #13
SteveB31
SteveB31's Avatar
No 1928 or 1929 radiator shells were stainless. When Ford designed the 1930
Model A Fords, they decided that the radiator shell, tail light, headlights, cowl band and cowl lights were to be "rustless" steel. Likely this was to save money, since it is cheaper to polish stainless, rather then plate steel.
Old 05-05-2017, 12:48 PM   #14
Neil Wilson
Neil Wilson's Avatar
Through June 1930, A and AA commercial vehicles had the same shell as the A passenger vehicles (through December 1929). These commercial shell were black painted steel. The A passenger shell was nickel plated steel. The A passenger shell was change in design and was stainless steel starting January 1930.
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
Old 01-24-2021, 08:24 PM   #15
ricconhan
ricconhan's Avatar
I was told that my 30 CCPU has a commercial shell and radiator
"I'd rather be sitting in my A Model thinking about God, then in church thinking about my A Model."
ricconhan is offline   Reply With Quote
Old 01-24-2021, 08:53 PM   #16
SteveB31
SteveB31's Avatar
It has an AA truck radiator shell and likely radiator. Not a pickup truck one
Old 01-24-2021, 11:32 PM   #17
Chris Haynes
Note that while the '28 and '29 appear to be the same there are differences in the stamping around the crank hole.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-25-2021, 05:38 PM   #18
Dan Partain
Dan Partain's Avatar
In addition to what Chris listed, the holes for the headlight conduits are smaller in the 28 and early 29 shells with the round crank hole cover. The hole size was increased in 29 to accommodate the Twolite headlights and conduits that used 3 wires instead of the 2 wires used on the earlier headlights.
Dan Partain is offline   Reply With Quote
