Old 09-22-2016, 08:53 PM   #1
My3window
My3window's Avatar
Default 34 Ash Tray Radio Electrical Connections
Does anyone know a source for purchasing the power lead connection and antenna lead connection for a 34 Model N radio?
My3window is offline   Reply With Quote
Old 09-22-2016, 09:44 PM   #2
VeryTangled
VeryTangled's Avatar
Default Re: 34 Ash Tray Radio Electrical Connections
Hi Everyone. My3window, I'd try your question here too.
http://www.earlyfordv8.org/forum/vie...s.cfm?Forum=18
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 09-23-2016, 06:27 AM   #3
Terry,OH
Terry,OH's Avatar
The power lead is just a black wire with a metal fuse holder. Do you have the fuse holder?? Antenna lead, I am not aware of a source at this time. It would be easy enough for a wire shop to cover modern antenna cable with cloth. You may be able to fish a new wire inside the original cable. Again the metal connector that plugs into the antenna lead and it's special connector??? I believe it was Narragansett Reproductions has the metal fuse holder. They may also have the antenna connector. Don't forget about the power lead for the head light bulb and it's special connector???
