08-29-2016, 10:15 PM | #1 |
1934 Rumble Step Pad Brackets
I'm looking for the measurements of the upper inner fender bracket that supports the top rumble seat step pad on 33 - 34 rear right rear fenders. The EFV8CA Restoration Manual shows a photo of the bracket in chapter 7 page 25 but it does not show where the bracket bolts to the inner rear fender pan or what kind of bolt/fastener was used. I have not found this piece available on the after market websites. Any measurements and photos of how it is fastened would help me fabricate this part.
I did purchase a bracket that supports the first step pad that mounts beneath the right tail lamp. It is made by Vintique, but unfortunately it does not fit because it is too short. Thanks for your help! Tom |
08-29-2016, 10:20 PM | #2 |
Re: 1934 Rumble Step Pad Brackets
Only the tail lamp step plate has a bracket there is not one for the large upper pad.
08-30-2016, 11:00 AM | #3 |
Your reply surprises me in consideration of the 33-34 Restoration Manual mentioning and showing a partial photo of the reinforcement bracket.
08-30-2016, 11:54 AM | #4 |
A few weeks ago I asked the same question to David Rehor and he confirmed there is no bracket on the upper 34 fender step pad. I should also point out the 34 restoration book is great but there are a few errors in the book.
08-30-2016, 02:26 PM | #5 | |
http://www.earlyfordv8.org/Ford_Book_Corrections.cfm The 33-34 book shows five corrections.
08-30-2016, 06:15 PM | #6 |
08-30-2016, 06:55 PM | #7 |
The original question was not about "40-13468 reinforcement (rear lamp bracket step) (with rumble seat)", but rather the homemade-looking support for the upper step pad on the top of the fender shown on page 7-25 (the blue fender and fender well). Because of the larger footprint of the upper pad, the greater curvature of the fender at its apex, and the closer proximity of the pad the bolts attaching the fender to the quarter panel, the location of the upper pad is inherently much stronger than that of the tail lamp bracket thereby eliminating the need for extra support for the top pad.
Agreed that the depicted top pad brace is not one of the five book corrections on the Club web site. |
08-31-2016, 06:19 AM | #8 |
40-13468 is the brace pictured on page 7-25 on the car with the blue paint and in question . Below is the diagram from the chassis parts book, with the basic part number. Fords description is: "Reinforcement (rear lamp bracket step) (with rumble seat)"
It appears, from the description, the brace is on the tail light bracket, NOT on the upper step. The restoration book MAY shows the brace in the wrong location, but the photo in the restoration book is too confined to the brace to determine the mounting location pictured . The brace, does exist. Last edited by Terry,OH; 08-31-2016 at 06:33 AM. |
08-31-2016, 07:48 AM | #9 |
Not to digress from the question of utilizing braces, but I would not let anyone step on either step pad, braced or not. Just my thinking on safety. I use a step ladder to get in and out of the rumble seat or put the top down to get in over the front seat. What happened to the grab bars used earlier?.... Cost maybe or before liable suits, were they as common as today?
Assumption is the mother of all foul-ups. Last edited by stangblue; 08-31-2016 at 08:05 AM. |
08-31-2016, 08:25 AM | #10 |
Terry,
With respect, please re-read My3window's first sentence where he refers to "upper" and "top pad". He is not referring to the lower pad which is reinforced by 40-13468, which no one denies exists and is shown in the parts catalogue. Also please look again at the photo in blue and you will note that the part shown is not formed like 40-13468 with its unique shape at the top to provide clearance for the nut and lock washer (and to provide additional strength). Also, please turn to the next page (7-26) which shows two photos of other installations of 40-13468 and note that in every instance the tail lamp reinforcement (40-13463) shows in the same photo as well as the filler plate between the body and the fuel tank cover/rear fender attachment point, which is not the case in the blue photo on page 25. There's no question that the man was asking about a brace for the upper pad, not about the lower pad on the tail lamp bracket. |
08-31-2016, 08:35 AM | #11 | |
08-31-2016, 11:07 AM | #12 |
42merc, Thank You for the correction. I thought they were used to help with ingress to the rumble seat. Interesting how we perceive things as we get older. :-)))
Assumption is the mother of all foul-ups. |
