Old 04-23-2021, 02:46 PM   #1
Rob Doe
Default Intake and Exhaust manifold nut torque
Well, I watched a You tube video that stated some guys tighten to 25 foot pounds while others go all the way to 60. I checked the torque on mine yesterday and found they were around 25. I upped them to 30. Looked in the Les Andrews book, but didn't find a recommendation.
In the back of the book, it has a torque chart that gives numbers for 7/16 bolts, grade 2, 5, and 8. It lists dry and lubed etc. But, it doesn't say anything about a stud.
What say y'all.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 04-23-2021, 03:31 PM   #2
Jacksonlll
Jacksonlll's Avatar
Default Re: Intake and Exhaust manifold nut torque
Les Andrews book says 45 ft# but I think that is a bit high. I use between 35 and 40.
Old 04-23-2021, 05:15 PM   #3
J Franklin
J Franklin's Avatar
I like 35 ft#
Old 04-23-2021, 08:53 PM   #4
JoeCB
JoeCB's Avatar
"good and tight" is about right !! I suspect that about 99.9% of all Model A's lived their first 50 -60 years without ever encountering a torque wrench.
Joe B
JoeCB is offline   Reply With Quote
Old 04-24-2021, 10:13 AM   #5
katy
katy's Avatar
Wot's a torque wrench?
Old 04-25-2021, 08:29 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
The cup washers on the manifold studs are springs that accommodate thermal expansion. The washers should not be compressed by tightening the nuts. Just tighten the manifold nuts enough to stop any leakage with the engine running and hot. Periodically check for leaks and snug the nuts to stop any leaks found.
Bob Bidonde
Old 04-25-2021, 10:16 AM   #7
Rob Doe
Thx all.
