07-01-2014, 09:42 PM | #21 |
Re: changing plugs every 100 miles!!
Not the best idea to be running a racing intake on the street. With no heat on the manifold you are just asking for drivability problems.
07-02-2014, 08:39 AM | #22 |
fuel fuel fuel fuel------------too much fuel....................=black plugs.........
07-02-2014, 08:46 AM | #23 |
Try .043 jets and .71 power valves if you are running 2 97s.
07-02-2014, 09:18 AM | #24 |
i agree Jack....with this intake new plugs the engine needs about 10 minuts to worm and run fine....but when is worm the response is good.....by the way i have the plug problem before i put this intake....thanks for the contribute!
07-02-2014, 09:21 AM | #25 |
07-05-2014, 04:06 AM | #26 |
07-05-2014, 05:37 AM | #27 |
With the Navarro racing intake. I ran one on the street, this is what I found works best from cold.
Start the engine, let him run for 2-3 minutes. If it's real cold, you'll see the carbs start to frost. Shut him down. If they were frosty, you'll see them thaw as the engine heat soakes the intake/carbs. Then start him up. And away you go. When doing it this way, the engine ran like a long dog. And would do so for the rest of the day. Only needing the heat soake after a overnight rest. Bit of a palavar, but work good. Next one will have a heated intake. Martin. |
07-05-2014, 12:24 PM | #28 | |
BTW...this may seem elementary, BUT make a check list and check off 'things' as you go along and like a map will keep you on track and possibly lead to solution. If you are like some of us with older/fuzzy brain cell, maybe helpful |
07-05-2014, 01:17 PM | #29 | |
07-06-2014, 05:54 AM | #30 |
I haven't seen the plug gap discussed as yet but if you are running 25 - 28 thou you should open them up to 40 thou and give it a try. You might be suprised at the diffence. Todays crap gas needs a good wide spark to fire it properly.
07-06-2014, 07:16 AM | #31 |
A few things, I'd find a distributor machine and get the ignition sorted out on it and have caution with a hottor plug as they leave more heat in the engine and a flattie can have issues with heat.
You say that you had same problem before the navarro intake, did you have mutiple carbs then? I ask because you say at least som eof the carbs are recent - correct? so the problem might go back to a particular carb? For instance, if you originally had a single 97 on it and had overrich plugs and then you went with a navarro with an additional carb you purchased from the UK and still have the sam eproblem, then I'd be looking at the original carb - see what I mean? When troubleshooting carbs I take them off the engine, raise them above the bench with 10" tall 5/16ths threaded rods (3 or 4 of them installed in the bolt holes) and then pump fuel into the carbs and see if they dribble under pressure. Fix each carb before reinstalling on the engine. I tend to isolate, test and fix each componant away from the engine and then test/tune as an assembly after I know with certanty that each componant is working proper. If you have one carb with a dribble from powervalve, another carb with too low a float and an ignition with leaking vacuum pot you will go nuts trying to find just one thing to fix and the problem is like chaseing a ball of mercury. |
07-06-2014, 09:47 AM | #32 | |
Still feel as if the problem is fuel....... |
07-06-2014, 03:24 PM | #33 | |
07-06-2014, 03:28 PM | #34 |
If you don't have some kind of air restriction, my bet is on your jets.
MIKE (mikeburch) |
07-07-2014, 12:21 PM | #35 |
first test with the ngk b4-l plugs....engine fire up at the first attempt and seems to run good...no time to run on the Street cause is raining....i start the engine without ballast now....coil primary is 2.5 ohms.....i'm waiting now the new jets and power valves....Tomorrow i restart the flathead just to see how the plugs color became.....
07-12-2014, 11:44 AM | #36 |
Well ...today i open the old 97 and that's what i try ....the accelerator pump is damaged....and the brass float has liquid inside...that's the other parts i need to change inside the carb....
DSCN4351 (640x480).jpg |
07-12-2014, 03:02 PM | #37 |
Sounds like you found the problem.
Float was not shutting of the gas at the right level.
[FONT=Comic Sans MS] |
07-12-2014, 06:00 PM | #38 |
Yep your float has a crack in it. Easy way to test after & if you solder it is broil ,or get it pretty hot, some water & submerge the float & watch for bubbles. Make sure you empty the fluid out first & if you get too much solder on it you will have to set the float level by guessing & adjusting . More float weight = it will set lower in the bowl & the fuel level will be too high.
07-12-2014, 06:51 PM | #39 |
First that pump is savable, with some care and whill your waiting for parts, take it off the carb cover, and find a tube, bottle top, maybe a 5/8 socket and put the pump rod down inside and pull the leather up around the spring, and reshape it ,,,now soak it with "neatefoot oil" or good hand cream with lanoan?? something good for leather, it will come back to life, or good enough... I would also polish the hole the pump work's in, some one pushed it in, without running it around at the start, opening (its tapered)... you don't need a lot of pump, as to where those carbs. sit.... try it sometime when all else is work and running good ...take both pump rods off and give it a run, like at 30 or 40 put in second bring the engine up to speed, now step on it hard.it should pick up and run from the get go. untell you run out of RPM's
Now as your waiting for parts, put the top back on the carb. ( no pump) ok. run the engine up to temp. get a good clean clear piece of glass. look/watch inside the carb in question, engine running at ideal, watch for moor gas to drip in, bring the engine speed up, 800 to 1000 rpm's and look some more.... you should trace the runners in the intake ,and find the plugs blacker than the others ?? they may be cooler than the others as they are weather ?? something to think about ..... OLD.....BILL |
08-24-2014, 02:05 PM | #40 |
brass float and fuel pump changed.....i put 0.69 power valves and 41 jets....now the engine runs very well!!
