02-25-2013, 12:17 AM | #1 |
"D" shaped captive nuts on bodies
I know this is an old question, but I'd like to be sure. Were the "D" shaped captive nuts used on Briggs bodies only and never on Murray built bodies? Thanks, Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
02-25-2013, 12:37 AM | #2 |
Re: "D" shaped captive nuts on bodies
Captive nuts murray.
02-25-2013, 12:52 PM | #3 |
For the 1931 Slant Window 160A, B, and C - Ford had Murray and Briggs build the bodies to the same design, hence all 160's have side windows with curved upper frames. On the 160's d-nuts were used on Briggs bodies firewall and caged nuts were used on Murray bodies firewall.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 02-25-2013 at 10:52 PM. Reason: clarify the use of d-nuts and caged nuts on firewalls of 1931 160 body styles |
02-25-2013, 01:06 PM | #4 |
Not to confuse the issue any further, but hard and fast rules regarding Model A production seem to be confusing. I have heard for years that Victoria bodies built by Murray did not have "D" nuts, only Briggs bodies.
But....I have seen Murray built Victoria bodies with "D" nuts at the cowl attachments and where the steering column passes through, with caged nuts elsewhere. |
02-25-2013, 08:47 PM | #5 |
My 160B has both caged nuts and D-nuts in various places. The firewall has D-nuts everywhere, but the dash rail has caged nuts. The door parts generally had caged nuts, but the rear subrail had D-nuts. And no body tag, trademark stampings, or assembly plant stampings...
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com My restoration diary: http://dougbraun.com/blog |
02-25-2013, 09:11 PM | #6 |
02-25-2013, 10:50 PM | #7 | |
With the d-nuts on the firewall it would be a Briggs body and there should be a Briggs "Bug" on the cowl. See the attached photo.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 02-26-2013 at 10:45 AM. |
02-25-2013, 11:24 PM | #8 |
"CAPTIVE CAGED NUTS"???----"D-NUTS"??? Ol' Bill W. won't explain! He just FEINS "hard of hearing" Buster T. (Dog)
02-26-2013, 12:22 AM | #9 |
I should have been more specific in the original post, I have a 1929 Fordor cowl and the dash rail screws go into "D" type captive nuts. Bob
02-26-2013, 12:38 AM | #10 | |
D-NUTS - the whole assembly is one piece and fits into a "D" shaped hole in the metal. Caged nut D-nut
02-26-2013, 08:41 AM | #11 | |
Doug
