02-17-2013, 09:40 AM | #1 |
#78- FH top loader case w/ full rib-Really stronger than one without it?
I posted the same question on the HAMB as well.
More curious for I happen to have both types of cases. Does anyone know for certain if the 81A flathead top loader trans. case with the full length rib (truck & light commercial) cast into the bottom of the case is stronger than the ones with only the "half" rib? I always thought the weakness in these transmissions was when they get too much fore or aft backlash in the cluster. Once this happens, they bind and grenade. I'm trying to figure out how much the case can do in helping this from happening. Thanks. Last edited by Tim Ayers; 02-17-2013 at 11:25 AM. |
02-17-2013, 10:57 AM | #2 |
Re: 81A FH top loader case w/ full rib-Really stronger than one without it?
