09-09-2012, 05:32 PM | #1 |
"46 Ford Coupe!
I have a '46 Ford coupe and I need new Hood Springs. can someone tell me the lengh? Or post a picture?
09-09-2012, 07:46 PM | #2 |
Re: "46 Ford Coupe!
The P/N is 99A16789. The dimensions are Total length 5 13/32, Coil length 3 13/64, Coil diameter 1 1/8, Wire diameter 5/32. Suggest trying to obtain the correct Ford p/n springs as it does'nt take much of a variation to keep them from working properly. They will also wear out at some point and your hood will fail to stay up. This was one service replacement part that did the job as advertised.
09-09-2012, 11:37 PM | #3 |
Re: "46 Ford Coupe!
Here's the spring at Mac's for $4.95: http://macsautoparts.com/early-v8-fo...0R3CHL1074017/
For twice as much you can get it stainless steel: http://macsautoparts.com/early-v8-fo...0R3CHL1113189/
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
09-10-2012, 04:03 PM | #4 |
Re: "46 Ford Coupe!
