Old 05-08-2020, 05:25 PM   #1
philipswanson
Default Mounting Data Plate on a 40
I was wondering how to get those darned rivets out so I can mount a new data plate I bought. I tried grinding the head off one of the old rivets and pounding it out with a hammer. Won't budge, instead is dimpling the sheet metal. Tried to drill the same one out but it is super hard. The drill won't phase it. Anybody have a secret to changing these? Access is hard because the motor, etc. is still in the car. I did rip the old tag off but the rivets are still in place and won't budge.
philipswanson is offline   Reply With Quote
Old 05-08-2020, 05:30 PM   #2
Kube
Kube's Avatar
Default Re: Mounting Data Plate on a 40
Grind more of what remains of the nail away and with a small pointed drift, knock it in to the passenger area.
So as not to disturb paint, I'd suggest a small round head burr cutter - 3/16" diameter max...
Old 05-08-2020, 06:18 PM   #3
philipswanson
Too late for the paint. Already wiped that out. I hate to grind on it any more because the metal is getting thin there and I have already ground it smooth across the rivet head and then some. I tried the pointed punch but it just dents the area. I am going to have to bondo the area and repaint as it is. The small teeth on the shank of the rivets make them difficult to remove.
Old 05-08-2020, 06:47 PM   #4
Kube
Kube's Avatar
They're not rivets. They are drive nails.
The small diameter round burr cutter works. I've done maybe one or twenty using this method and have never once hit the paint.
Old 05-08-2020, 06:59 PM   #5
philipswanson
Paint is the easy part. I have to fix the dent from all the pounding with a sharp punch. I plan to grind them all smooth, JB weld the new plate in place a tad over and drill new holes for the new nails. I gave up on trying to knock the old ones out. You grind them smooth and then pound on them and the firewall just dents but they still don't come out.
Old 05-08-2020, 07:04 PM   #6
Kube
Kube's Avatar
Hmmmm…. I've never had that issue.
Mike Driskell sells small screws that look just like the heads of the drive nails.
Old 05-08-2020, 10:07 PM   #7
philipswanson
Using a scribe, I managed to knock out the first one. Problem is it hard to get any leverage and swing a hammer at the right angle. Also I am not in the best of shape. Thanks for the help.
Old 05-09-2020, 11:01 AM   #8
blucar
blucar's Avatar
From my experience the "drive nails" Ford used to attach many small data/serial num plates for many years were quite easy to remove.
Bill.... 36 5 win cpe
