05-24-2010, 09:24 AM | #1 |
"41 pickup torque tube help!
Trying to assemble a pile of iron bought as a '41 pickup. Missing stuff, wrong stuff, etc. Biggest problem is identifying what the torque tube should be/have. It was missing radius rods, got a pair via the Barn, correct for '41 but too short and won't fit over axle housing. It's a 112" WB. The Torque tube is 70" long. There is no evidence of it having had a bracket to affix the front handbrake cable and hydraulic fitting. We removed the fitting to mount the front of the radius rods, thinking to reweld to match the length of the short radius rods (99A-4750 now for resale).
So, we need some help from someone with a '41pickup or knowledge of the running gear. Help.....Don |
05-24-2010, 10:31 AM | #2 | |
Re: "41 pickup torque tube help!
05-24-2010, 10:50 AM | #3 |
post some pic's of what you have as pic's always help.
05-24-2010, 11:04 AM | #4 |
Jerry is correct. '41 pickup running gear is the same as '39 & '40 cars and pickups. Here are a couple o pics of the front radius rod mount on mine.
05-24-2010, 02:06 PM | #5 |
Hey Don, 70" is the correct length for your application. There is a bracket held on by the front radius rod bolt (see pic). The brake fitting that splits the brake lines is bolted through the left radius rod, again see pics. Tha hole is located on the top of the rod approximately 7 1/4" back from the front of the rod. The hole should go all the way through the radius rod. If I can be of anymore help, please feel free to ask. Dennis/Arkansas
05-24-2010, 06:08 PM | #6 |
www.fordcollector.com |
05-24-2010, 06:13 PM | #7 | |
05-24-2010, 06:33 PM | #8 |
05-24-2010, 07:04 PM | #9 |
My 80 year old next door neighbor has a ‘41 Ford Pickup he bought from the original owner 40 years ago. This one is pretty original, it is loaded with every available option, all two of them, sun visors and a column shift. From the looks of it I don’t think the rearend has ever been out of it. I crawled under it and got you some photos of the original rearend hardware and brake lines. In my opinion the ‘41 Ford Pickup is the beautiful pickup ever built. I have dibs on this one!
Jerry |
05-26-2010, 07:02 AM | #10 |
Wow! What great responses! And pictures to boot! We'll probably have to make up the hand brake bracket. Will now have to find a pair of '37 to '40 radius rods. We had a quick response when we asked for a '41 set, which we'll put up for resale. As an aside, the cab has been restored by Dave Simard with just beautiful metal work!
I've got to figure out how to print just one picture and how to get full right margin of text. |
05-26-2010, 07:22 AM | #11 | |
Hey Don, If you'd like a tracing of the bracket, I'd be happy to send it to you. Let me know. Dennis/Arkansas
