12-10-2015, 06:16 PM | #1 |
"31 Vicky rear Fender mounting point question
I am trying to put a Vicky back together that came missing some components as well as having had someone in the 1960's do some unskilled sheet metal work on it. I bought Brookville rear fenders for this car and as they have no mounting holes and the wheel wells were somewhat reworked I do not have studs in the wheel wells either. There were holes drilled inn the wheel wells but I do not know if position is correct. I put one fender in place.... well where I believe it fits but before I go drilling holes in the fender and welding studs in the wheel well I would like to know where I am at as a lot of trial and error with holes is not a good thing !. I drew an arrow to the front edge of the fender where it meets wheel well. Is it supposed to be flush with the dill ? Or ? Any info would be a great help !!!!
12-10-2015, 07:07 PM | #2 |
Re: "31 Vicky rear Fender mounting point question
Bonniewwyn, perhaps these photos of the insides of a Victoria wheel wells will help.
Not sure what you mean by your question..."Is it supposed to be flush with the dill ?" Last edited by Vern; 05-30-2020 at 08:10 PM. |
12-11-2015, 07:55 AM | #3 |
