10-17-2015, 02:33 PM | #1 |
distributor question
pulled distributor and it has the 1 piece shaft ones i have seen has been 2 piece,shaft seems ok but would 2 piece be better
10-17-2015, 02:38 PM | #2 |
Re: distributor question
Yours is fine
10-17-2015, 02:42 PM | #3 |
1 more question shaft has a groove close to top like maybe clip,but had non
10-17-2015, 02:56 PM | #4 |
When you say close to the top do you mean just below the distributor cam
or just below the bottom of the distributor body?? Bob |
10-17-2015, 03:12 PM | #5 |
Or do you mean at the bottom of the shaft-the end that goes into the engine?
Fred Kroon 1929 Std Coupe 1929 Huckster |
10-17-2015, 03:17 PM | #6 |
10-17-2015, 05:17 PM | #7 |
I think you are missing the seat for the distributor cam. I just
rebuilt my distributor and it was missing, I don't know how it stayed in time. Bob |
10-17-2015, 06:48 PM | #8 |
thanks its clear now
10-17-2015, 08:29 PM | #9 |
Vince, I think this is a 60's JC Whitney part.
Bob |
10-17-2015, 09:15 PM | #10 |
This is the one piece shaft that came out of my distributor. Notice it has no machined flange, and there is a slot in the bottom. I replaced it with the two-piece upper shaft with the machined flange and the lower shaft with two slots..Btatton's # 17370 and #17530. There were a couple of washers/spacers there that the cam pressed against...
That collar is pinned but it just slides on...there is no coupling there....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
10-17-2015, 10:18 PM | #11 |
that is what i have,below cam is a groove,i guess what i need is 2 piece shaft thanks
10-17-2015, 10:28 PM | #12 |
I replaced the cam/oil pump drive gear with a slightly oversized one from Bert's....004" over, and replaced the single long distributor shaft with the two piece shaft...it really tightened up the distributor drive..there is very little play in the rotor now...
