05-20-2014, 03:48 PM | #1 |
rivet help!!!!!!!
I need to rivet 3/16 inch rivets and a tandem type 351 seems to have the power ....but these are expensive. Does anyone rent these [I found Hansen rivet does but only in California where I do not live]?
Any other ideas thanks Ed Solari |
05-20-2014, 04:44 PM | #2 |
Re: rivet help!!!!!!!
Where are you installing the rivets ? Can't you use a snap and a hammer ?
05-20-2014, 07:12 PM | #3 |
Everything above 5/32" is a chore. I've had good luck with squeezers on the little rivets but you need a really big one for 3/16 or larger rivets. I assume you are refering to steel rivets for frames and such. I still buck them with a 5X Cleco pneumatic hammer and the largest bucking bar I can muster. If they don't give, I heat them with the oxy/acetylene torch till they will. At some point I'm going to try to make my own hydraulic squeezer but I need to tool up for that.
As far as renting one, I've never tried so I'm not much help there. A person hase to have all the heads for a squeezer so I would hope you have access to those too. Mose squeezers use the same tooling and sets aren't to bad a price. |
05-20-2014, 09:40 PM | #4 |
