05-20-2014, 07:15 AM | #1 |
1939 window garnish moldings
What is the proper name for the interior exposed metal frames around the windows? They are painted like the dash? That frame inside on the windshield is in 2 pieces. The top joint is covered with the rear view mirror and the bottom joint has a small cover plate. I need that bottom cover plate. Any ideas? Thanks. Jon Laing
05-20-2014, 08:10 AM | #2 |
Re: 1939 window garnish moldings
Jon, Mac's in Lockport ,NY, has them in the 2012 catalog.Their # is 1-800-777-0948.
Hope this helps. |
05-20-2014, 08:38 AM | #3 |
I called Mac's but they do not have one. Jon L.
05-20-2014, 09:21 AM | #4 |
Their catalog says you need 2, but in fact if you have the mirror you only need one, bought two. I have one extra but it is a 37, expensive little devils . Zeke
Only problem with retirement is never a day off |
05-20-2014, 03:02 PM | #5 |
Drake has em, page 308, at $15.00 to much, item #81A-701392, I just got it back from chrome, now I'll find the one that came with the car ....go figer .....OLD....BILL
05-20-2014, 03:37 PM | #6 |
MEMBER EMERITUS
05-21-2014, 06:12 AM | #7 |
Got one from bob drake. The first time I called they said they did not have one but your giving a part # solved the problem. Thanks. Jon L.
