05-19-2014, 07:15 PM | #1 |
8ba in a 37 sedan delivery
I think I posted this engine awhile ago while I was building it. I just got around running it. It seems good to run a stock engine once in awhile, it's so smooth. I'm use to building these street engine with cam and carbs ect. Walt
05-19-2014, 09:03 PM | #2 |
Re: 8ba in a 37 sedan delivery
It takes a lot of will power to do one TOTALLY stock.
05-20-2014, 02:57 AM | #3 |
It looks awesome Walt, can't wait to hear it Purr! Ray
05-20-2014, 05:09 AM | #4 |
What is the setup for running a fan on an 8BA in a 37? The stock setup won't allow you to move the generator forward and keep the stock fan. The 8BA generator is forward. What is done?
05-20-2014, 06:51 AM | #5 |
Ray may answer that question. He has ran this setup in his 37 delivery. If it was me I probably would use an electric fan. Walt
05-20-2014, 09:01 AM | #6 |
Many years ago I did a couple of 8BA engine swaps into '36 and '37 Fords. The main issue to contend with is the 8BA water-pumps.. You have to have either truck or '49/50 Merc pumps that have the motor mount ears incorporated into the pumps. You also need the '49-50 Merc mount spacers as shown in the attached pix. The '49-50 Merc mount spacers have an off-set in the bolt pattern, plus they compensate for the shorter 8BA pumps. Using the exhaust manifolds that are correct for the vehicle also makes the swap easier..
Bill.... 36 5 win cpe |
05-20-2014, 04:51 PM | #7 |
The 8BA in my Panel is using a generator mounted Fan maybe from the original engine. , truck water pumps, and regular motor mounts. It fits perfect. If I knew how to post pictures I would. Ray
05-20-2014, 06:32 PM | #8 |
My memory is that the 37-39 trucks had a higher top tank and more space between the engine and the radiator than the 37-39 standard 85 horse sedans. There is limited room between the generator and the radiator in the stock 85 horse 37-39 sedans.
I guess if you used the very short fan from a 35-36 then the more forward 8BA generator would work with a fan on it. I am aware of the water pump, bell housing, and exhaust manifold needs, thanks though. |
