05-20-2014, 12:56 PM | #21 |
Re: Flaring Stainless tubing
Thanks woodiewagon46, I read somewhere about the work hardening caused by the rolling tubing cutter and have been cutting the SS tubing with 3" cut off wheel and filing the end square. Seems the ID and OD beveling is important too. I'll see how the Mastercool flaring tool works and let you guys know.
Howard |
05-20-2014, 01:00 PM | #22 |
Corrosion resistant steel is a different animal than anything else used for tube, hardware, or even sheet stock material. It's softer than most folks realize but work hardens easily. In the threaded fasteners , it has a tendency to stick to parent material that it is threaded into. This causes galling and makes it a must to use anti-seize compounds. It isn't easy to anneal the stuff and procedures to do so are complicated. The race for better aerospace materials during WWII helped develope most of the procedures for using it today.
Aerospace uses the SS tubing and other materials for high heat applications where it's too expensive to use titanium but neither are easy to work with. SS is easier to drill & machine than titanium but not by much. Most everywhere else, the aluminum or braided stainless covered synthetic rubber hose is utilized for ease of maintenance and reliability. SS has its place but it's also limited by weight too. |
05-20-2014, 01:11 PM | #23 | |
Given that these lines are just low-pressure oil or fuel lines, single flare them and be done with it if you have to use stainless and can't use a 37° AN/JIC type fitting.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
05-20-2014, 01:22 PM | #24 |
Rotorwrench, We used to refer to stainless as "gummy" when discussing taps to be used in stainless. I had a brief job experience, (Vermont American), doing special tap specs. for our customers shop orders. When cutting the flutes for stainless and aluminum taps we used a 16-18 degree hook to effectively curl the cuttings into the flute. For comparison, we called for a 0-3 degree hook for tapping abrasive materials like cast iron and bakelite. A higher hook tap used in these applications would prematurily wear out the tap. Our general purpose taps had a 6-8 degree hook. Good info. on this forum.
Howard Last edited by HCO41; 05-20-2014 at 01:31 PM. |
05-20-2014, 01:48 PM | #25 |
I fancy the cutoff wheel may also work harden the stainless a tad. Best very fine hacksaw would do the job best.
Martin. |
05-20-2014, 04:51 PM | #26 |
Thread Tools | |
Display Modes | |
