02-16-2014, 08:19 PM | #1 |
"40 Ford steering worm condition?
Replaced sector shaft & roller with NOS unit, the old one was badly worn. To me the worm looks to be in good condition and would like any opinions as to whether it's okay to use it.
02-16-2014, 08:26 PM | #2 |
Re: "40 Ford steering worm condition?
Looks okay to me. If the other side is as nice, use it.
02-16-2014, 08:44 PM | #3 |
02-16-2014, 08:54 PM | #4 |
Nice part... Better than anything you could get new...
Karl |
02-16-2014, 10:50 PM | #5 |
Appearances can be deceiving. It does look good. No galling which is a great sign. Only way to know for sure is put it together and see how much play you end up with. Good luck!
02-17-2014, 01:26 AM | #6 |
02-17-2014, 10:39 AM | #7 | |
02-17-2014, 11:05 AM | #8 |
I have seen a few like that. The worm may be worn, so like Russ said, assemble it and see it you can adjust the roller to worm.
Here is how I do it... Adjust screw on side cover until there is no end play in the sector. Count the number of turns of the steering shaft from lock to lock (for a 18:1 it should be 4-1/2). Count back from one lock 2-1/4 turns to find center. Fine tune the sector adjustment at the neutral center position. There should be a very slight drag in the neutral position, as that helps the steering stay straight as you drive down the road. It will feel looser as you turn the wheel off of center. If it gets tighter off of the neutral/center position, then the worm is worn beyond use. Hopefully the worm is still good, let us know what you find. Neal |
02-17-2014, 11:17 AM | #9 | |
02-17-2014, 11:21 AM | #10 |
40 Ford, why the horn rod? The worm pictured looks good. many times the sector roller seizes and this can cause rapid ware. There should be no reason why the worm end play can not be shimmed properly Make sure the gasket shims have the center hole large enough for the race to pass through. A new or roller replaced sector adjusted. Take a look at the filler plug and see if is marked "fill with heavy gear oil" or fill with "John Deere corn head grease" Heavy oil is the same weight as the transmission and differential 140W
02-17-2014, 01:59 PM | #11 |
02-17-2014, 11:49 PM | #12 |
Okay, got it back together. What prompted the rebuild was play in the sector shaft of about 1/8" in rotation in either direction, when transferred to the end of the pitman arm made the car uncontrollable. There is no slop or end play now. My only concern now is the steering shaft may have too much drag; I used 5 of the 6 shims supplied and it seemed to be just right, added Permatex and tightened the 4 bolts. Added John Deere grease & will install tomorrow and see what it feels like with steering wheel on.
02-18-2014, 01:15 AM | #13 | |
