07-19-2013, 02:10 PM | #1 |
>>1935 Rear Banjo: Can I stuff it with later gears?<<
Could I put a 1939 3.78 gearset into a '35 Ford Banjo without issues besides the Torque tube stuff? Would the axles work or would I have to get later axles as well?
Any info would be greatly appreciated.
I PLAY WITH TIGERS.
www.SUGARCITYSPEEDSHOP.com |
07-19-2013, 03:41 PM | #2 |
Re: >>1935 Rear Banjo: Can I stuff it with later gears?<<
They go right in. You use the 35 axles, bells and the 35 side bearings. The bearings on the carrier are the same I think. I tried to use the later housing bearings and that sure did not work. I used the later center section housing. I believe the gears will interchange but someone more knowledgeable will pipe in.
07-19-2013, 04:49 PM | #3 | |
07-19-2013, 07:07 PM | #4 |
Thanks!! Loving the info!
I PLAY WITH TIGERS.
08-18-2013, 04:50 PM | #5 |
