Old 05-23-2020, 04:59 AM   #1
67triumph
Default 1938 Ford windshield seal help
Friends, I need some advice on a issue I have on my 1938 Ford pickup, I’m in the process is installing a new windshield seal, but I’m having issues with the seal popping out at the V-butt areas top and bottom and also a couple other spots, I checked the channel so many times to make sure nothing was in the way but nothing is helping, the frame is just freshly painted so I don’t want to damage it, I have some Napa windshield seal 4121 and thought about using that in those areas but I wanted to get some input and advice before I go that route. The seal is from Dennis Carpenter
67triumph is offline   Reply With Quote
Old 05-23-2020, 08:49 PM   #2
JSeery
JSeery's Avatar
Default Re: 1938 Ford windshield seal help
Bttt
Old 05-23-2020, 10:31 PM   #3
Tinker
Tinker's Avatar
What seal are you using? Can you post some pictures on the "v"?
Old 05-24-2020, 08:54 AM   #4
1931 flamingo
1931 flamingo's Avatar
Is it the same glass that came out or NEW glass??
Paul in CT
Old 05-24-2020, 09:15 AM   #5
TJ
TJ's Avatar
Paul in CT
I don't think the glass has anything to do with the gasket not fitting. The gasket on the '38 fits into the metal frame which in turn holds the glass.
