04-27-2015, 10:42 AM | #21 | |
Re: "D" Nut dilemma or should I say NO "D" Nut...
about not removing the "L" bracket. I just looked at some photos, thinking that there were 2 rivets at the center (for the spare tire bracket) but that's not the case.. |
04-27-2015, 11:09 AM | #22 |
Yes, the vertical support is riveted. None of this is a bid deal if you are restoring a car but I would look at alternatives doing this project on a painted car. Ultimately I would probably end up disassembling it but I can't say that for sure.
http://www.abarnyard.com/ |
04-27-2015, 02:21 PM | #23 | |
the photos that I used... Did I miss something..? |
04-27-2015, 06:12 PM | #24 |
Registered User
besides the two bottom rivets Ive found a few that had two spot welds at the top corners
04-28-2015, 01:18 AM | #25 |
Many of the previous suggestions seem to be oblivious to the fact that the vertical support (which Marco refers to) in the center of this panel assembly even exists. Any of these I've seen have been riveted in both top and bottom, and as long as this brace is in place I don't think there exists an easy or damage free way to remove the panel that Steve needs to replace the "D" nuts in. Am I missing something?
04-28-2015, 05:56 AM | #26 |
Will |
04-28-2015, 07:17 AM | #27 |
once the spare tire support is removed that panel will slide down out of the rear panel sometimes we over think the problems, we spend more time thinking how hard we can make it when 1 hour of working on the problem would solve it jmo
04-29-2015, 10:04 AM | #28 | |
were talking about. I thought the problem was the "L" bracket,....wrong. It's the exposed finish piece that's the issue. the exposed finish piece that's the issue. Yes, it's riveted in, top and bottom, and I can see why Pluck doesn't want to remove it from a painted and finished car. He does have a dilemma....which would drive some of us nuts... |
