Old 07-01-2022, 12:18 PM   #1
jeepguy1948
Default Folding Top
I have a 28 RPU as you probably all know the top is easily removed but does not fold. I have been told that a roadster (car) folding top can be installed with minor modifications, true or false?
jeepguy1948 is offline   Reply With Quote
Old 07-01-2022, 12:49 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Folding Top
Depends on what you consider "minor" as far as modifications go. Below is a picture that Marco Tahtaras made many years ago that pretty much shows you why I don't think you are going to find it a minor modification to install a 40A top assy. on a 76A body.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-01-2022, 01:26 PM   #3
Chris Haynes
Chris Haynes's Avatar
There is someone making folding irons for trucks.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 07-01-2022, 01:44 PM   #4
ronn
as Chris said and they arent very expensive either.
Old 07-01-2022, 02:17 PM   #5
Keith True
Keith True's Avatar
Who is making the top irons right now?I wanted to buy a new roadster body or open pickup cab a couple of years ago,but I didn't because the top irons were not being made.I had a set for a 28-29 open cab that I bought from LB close to 20 years ago.I wasn't interested in building an early style truck again,so I sold them a couple of years ago.
Old 07-02-2022, 06:14 PM   #6
ronn
actually speedway and Mikes had them for around 450.
both now sold out.......
Old 07-02-2022, 06:23 PM   #7
ronn
little dearborn showing them for around 500.
Old 07-02-2022, 07:47 PM   #8
Keith True
Keith True's Avatar
When I was looking for them I tried all the usual suspects.Some listed them online,but phone calls told me none had them and had no target date in sight.I did find some universal ones,like the ones I found at Summit,but they were fit-all,fit nothing right.Then I would have to have a top custom made,as the off the shelf A tops were nowhere near a fit.That was made very clear to me when I looked into them.In the early 2000's I bought a set of the folding irons from LB,and I think they were over $600.back then.
Old 07-03-2022, 12:44 AM   #9
rotorwrench
rotorwrench's Avatar
The alternative some folks take is to remake a top with snaps on the lower edge then modify the rear of the cab for snap attachment so the top can be removed. There isn't a very good place behind the cab for a folding top to rest.
Old 07-03-2022, 07:27 AM   #10
Keith True
Keith True's Avatar
I used removable fasteners on both my 28 and late 30 open cab trucks.Removing that roof makes for a very floppy and flexible cab.The later style much more so.I had bought the new folding irons for the 28,but after driving it with the top off I decided I didn't like the way it flexed.The universal ones from Summit are not remotely like the original in shape.But,if you have nothing and want to drive right now,and can make your own top,they would work for you.Last time I checked they were out of stock too,with no idea when or if they would be back.The boat top shops here says no problem,and charge time and materials.
