04-23-2022, 11:47 AM | #1 |
OK, ... I'm Stumped * Solved *
Hey All,
This morning, I was on my way to a car show in my "A" and out of the blue and half way there, my car started backfiring out of the tailpipe, very loudly so I slowed down and noticed it stopped, so I started to go again and the backfiring came back. It only happens when I go over 35mph. I pulled over and removed the carb, split it apart and tried to clean it on the side of the road. I put it all back together and the same thing happens. I limped it home and removed the carb again and tore it completely apart. I blew out all the jet's and passageways and float valve and reassemble it all. During the test drive, I'm getting the same thing. I do have strong flow from the steel line and the filter in the carb is clean. I tried opening up the GAV, but enriching thre fuel does not stop the backfiring. I then thought it could be the condenser, but I can get up to 2100 rpm in 1st gear with no backfiring until the bowl drains, but I cannot get past 1200 in 3rd without backfiring Any clues? Regards Bill Last edited by BillCNC; 04-24-2022 at 08:03 PM. |
04-23-2022, 12:40 PM | #2 |
Re: OK, ... I'm Stuped
Bill,
it sounds like maybe fuel starvation, how about the cap on the tank? try removing and run down the block. But, back to the backfiring, a friend had his Vicky out on morning and driving to a small car show in a quiet little town. The points slipped or the cam moved, in any event it backfired a couple times and he stopped. About 5 minutes later a handful of sheriffs cars come flying around with the lights on. I went over to chat with one and he asked if we heard any gunshots. When I explained that it was the Vicky backfiring he couldn't stop laughing. It was comical to hear him calling it in, laughing the whole time. The dispatcher, who had a sense of humor asked if there had been a Dillinger sighting? Best, John
As Carroll Smith wrote; All Failures are Human in Origin. |
04-23-2022, 12:52 PM | #3 |
The backfiring makes me wonder if your getting too rich a mixture. Try running with the gav closed. Also, if the brass seat for the gav is loose, that would get you a rich mixture. How do the plugs look? Also, the gasket for the carb, I would use a mirror, and a flat file on the intake/ carb surface, and dress up the top of the carb.
04-23-2022, 12:56 PM | #4 |
Apposed views of your situation, 50/50 chances of a diagnosis, take it for what it's worth.
04-23-2022, 01:03 PM | #5 |
What's the point clearance??
Paul in CT |
04-23-2022, 01:10 PM | #6 |
Look for something that broke in the carburetor or something that broke in the ignition system. The fact that it came on suddenly points to a broken part somewhere.
04-23-2022, 01:12 PM | #7 |
Well said.
04-23-2022, 05:47 PM | #8 |
Things I have done or checked:
Checked carb throughly Gas flow is high Drive without gas cap Points is .020 Rotor Gap is .030 Plugs are good Changed Condenser Fiddle with the GAV from closed and up to 2 turns open Distributor connections are clean and secure Inspected Cap components. Regards Bill |
04-23-2022, 06:09 PM | #9 |
Did you check spark? Take one of the wires from spark plug to distributor body and position it about 3/8” from terminal on distributor body. Start engine. Is the spark blue or yellow?
04-23-2022, 06:40 PM | #10 | |
Regards Bill https://youtu.be/MDvMWg_QR8U |
04-23-2022, 06:56 PM | #11 |
Better check for an intake leak
Sent from my iPhone using Tapatalk |
04-23-2022, 08:01 PM | #12 |
One or more plugs may have gotten damaged but you say plugs are good.
Check compression on all cylinders to see if a valve is not seating or damaged.
04-23-2022, 08:45 PM | #13 |
OK, ... Found it, or I hope thats all there is.
My armor cable is shorting out around the spark rod. It will arc to the rod and if I pull it away, it's stops sparking, but if I bend the cable in that area, it shorts and the engine dies. Can I fix the wire inside? Regards Bill |
04-23-2022, 08:47 PM | #14 |
Vacuum leak?
04-24-2022, 10:40 AM | #15 | |
You might be able to change the wire inside it, but, I just replace them. I like the thin flexible after market cable,, but mine is not a show call. Like many things, they can be a son of a gun to find the first time. A second or third is faster and easier. Last edited by Patrick L.; 04-24-2022 at 01:14 PM. |
04-24-2022, 10:56 AM | #16 |
Re: OK, ... I'm Stuped * Solved *
Well you weren’t stupid….
Ignorance can learn…. Stupid is forever |
04-24-2022, 11:00 AM | #17 |
I've seen a lot of those cables go bad.That fabric coated cable was never meant to last forever.I had one on my own go bad,the car would just randomly die.When I checked for spark,I would have it.It was blue but had no real strength to it.No big snap.I knew it was the cable because if I touched it the car would quit.I took the popout assembly out,then I saw scratches on the back of the switch and marks on the distributer end.Somebody had already tried to monkey with it before.I sent it to Mr Crabtree,he said it had a single strand of wire still intact,and one end was twisted.He repaired it and made me an extra key.
04-24-2022, 02:15 PM | #18 |
Bill,
good job finding that, intermittent issues are always fun. Thanks for sharing, John
04-24-2022, 04:45 PM | #19 |
I think your original posted misspelled stumped…
I Misread your misspelling!!!! Good job. Hope all works going forward |
04-24-2022, 05:02 PM | #20 |
Backfiring out the tail pipe? Backfiring from the carb lean mixture. “After firing” out the tail pipe ignition.
