04-18-2016, 12:11 PM | #1 |
tillotson carb fuel inlet repair
Started to connect the fuel line to the carb today and the nut wants to go in crooked like it has been cross threaded,so I did not force it.
If the threads are damaged can they be repaired?THANKS |
04-18-2016, 12:16 PM | #2 |
Re: tillotson carb fuel inlet repair
I would pull the carb and look at it closely.
I don't have much experience with tillys, but bad threads are one problem I am aware of. Maybe a new fitting will screw in properly. Bob |
04-18-2016, 02:31 PM | #3 |
Having said that I always start winding the fuel inlet on finger tight to ensure that I have the treads lined up properly before using a spanner ( aka wrench) |
