Old 05-19-2015, 05:47 PM   #1
kentucky1928
Send a message via AIM to kentucky1928
Default steering column questions
Hello everyone, I don't post on here very much but I get a lot of useful information here. I have been working on a 1928 ccpu off and on for a few years and today I started working on the steering column.The steering wheel is in bad shape so I took it off and it took me about an hour. I would like to find a good original steering wheel but I don't know what type I need and I'm not sure if it is a 2 tooth or seven. I am going to try to post some pictures. Thanks guys, Scott.
kentucky1928 is offline   Reply With Quote
Old 05-19-2015, 05:59 PM   #2
Charles Coe
Charles Coe's Avatar
Default Re: steering column questions
You have a 2 tooth steering column introduced in Feb. of 29.
Charles Coe is offline   Reply With Quote
Old 05-19-2015, 06:18 PM   #3
kentucky1928
Thanks charles I noticed my steering wheel has one slot and others I have seen have two for the key can you please tell me the difference.
Old 05-19-2015, 06:26 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Dog here,
I can answer that one, PLEASE, oh PLEASE, le'me answer it,
The difference is 1 UNUSED key slot---HA-HA-HA-HA-HA-HA-HA-HA---------
Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 05-19-2015, 06:31 PM   #5
Jwilli
Jwilli's Avatar
Bill W. I have learned to love your humor. Have also learned that it contains good advise. Keep it up.
Jwilli is offline   Reply With Quote
Old 05-19-2015, 07:15 PM   #6
sphanna
sphanna's Avatar
Just do not grease that even though it has a grease zerk on it.. You have to use same 600 wt gear oil as you would use in transmission.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 05-20-2015, 10:13 AM   #7
roblesterjr04
I just refurbished a 7 tooth column for my 29 fordor (even though what came out was a 2 tooth).
I understand that the 2 tooth is a more modern unit, however, the 7 tooth seemed more my speed to do a DIY refurb on. Much fewer parts, and far less expensive.
If you have a '28, wouldn't the 7 tooth column be the correct column? Maybe the column you have was installed later on?
-Rob
1929 Fordor Leatherback
roblesterjr04 is offline   Reply With Quote
Old 05-20-2015, 10:28 AM   #8
BILL WILLIAMSON
We'd probably be SURPRISED to know what parts have been changed/altered, even on "unmolested" cars!! When I bought my '32 -5 window coupe, it had a steering gear from some old Plymouth?? It worked very well & was in good condition.
We talk about "FARMER FIXES"----Don't forget about "WRECKING YARD FIXES"--"Yep, I'll make it fit"
Interchange Manuals came out while I worked at a wrecking yard, THEY WERE A GODSEND!
Bill W.
Old 05-20-2015, 10:45 AM   #9
roblesterjr04
Oh yeah, i'm no exception! Like i said, i'm putting a 7 tooth column in my April or '29 fordor
I got this car, found a rubber washer floating in the main jet, nut/bolts holding the brake rods on, 2x4s holding up the roof...
Right now my ignition switch is a push/pull switch, which was an upgrade to my previous redneck fix: a house switch. (pictured below)
-Rob
Old 05-20-2015, 11:14 AM   #10
barkleydave
barkleydave's Avatar
Sweet!!!!!!!!!!!!!!!!!!!
barkleydave is offline   Reply With Quote
