Old 02-18-2024, 07:47 PM   #1
dbandgb
Default 59 352/4 carb
Is the four barrel carb vacuum or manual to open when pressing the pedal? Stock Galaxie 59. Thanks
dbandgb is offline   Reply With Quote
Old 02-18-2024, 09:49 PM   #2
40 Deluxe
Default Re: 59 352/4 carb
Vacuum diaphragm on the back of the carb.
Old 02-19-2024, 11:03 AM   #3
dbandgb
Thanks for the reply. I just bought this car and it isn't delivered yet. Back in 59 I bought a new galaxie convert with a 332 in it. I changed the carb and manifold to a 4 barrel. It also was vacuum operated and it was a dog, say off the line. So I suppose this will be the same.
Old 02-19-2024, 12:26 PM   #4
5851a
The car was heavy, engine small and a ridicules high rear end gears with an automatic, 2.65 or some thing like that. Had a 332 4v and cruise o matic. Slow in town agree.
5851a is offline   Reply With Quote
Old 02-19-2024, 11:43 PM   #5
miker98038
miker98038's Avatar
You want to see a real bog, take that combo and put with a manual secondary on it. Full throttle from a stop gets nothing. Learned that driving a tri power on my first y block. This assumes the secondary vacuum unit (or air valve on other designs) is working properly.
miker98038 is offline   Reply With Quote
Old 02-21-2024, 02:37 PM   #6
40 Deluxe
With vacuum operated secondaries the rears do not open until the engine needs the extra airflow (maybe above 4,000 RPM) so off the line your 4 barrel carb is functioning just like a two barrel carb.
As mentioned in another post, rear axle ratio is a major factor. Plus, if your '59 Galaxie was an automatic it normally started out in 2nd gear unless you manually shifted it.
Old 02-29-2024, 04:50 PM   #7
Gene F
Gene F's Avatar
My tri-power doesn't start to open secondary carbs till about 60% throttle. I have the factory optional gear in the rear end. Took a lot of doing to get that point of opening, and then be able to get them 100% open at full throttle.
Old 03-01-2024, 08:53 AM   #8
Ford blue blood
Ford blue blood's Avatar
Short/long story about tri-powers. 73 F100, 360/granny 4/3.55 gave a good solid 12MPG under any driving condition. Put a Galaxie tri-power and headers on the engine, jetted the carbs down a bunch and it ran like a champ. The progressive linkage was perfect. Interestingly the set up raised the MPG to 15 as long as I kept my foot off the long pedal!
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 03-01-2024, 02:41 PM   #9
Gene F
Gene F's Avatar
I have no idea what highway mileage is on my car now. Heck it was 12MPG at 70MPH before, so I figured why not. LOL
