Old 10-03-2020, 11:30 PM   #1
Smitty
Smitty's Avatar
Default 1930 Fuel Bowl Leak
Hi All,
For some reason lately I have been experiencing a leak at the fuel line fitting fitting coming off the glass type fuel filter on my 30. When tightening the fitting it just wants to push the ferrel into the bowl rather than compress around the steel fuel line. I changed out the unit with a new one and does exactly the same thing. Do I need to revert back to a cast iron type unit?
Thanks, Steve
Smitty is offline   Reply With Quote
Old 10-04-2020, 05:26 AM   #2
Mike Peters
Mike Peters's Avatar
Default Re: 1930 Fuel Bowl Leak
The fuel line should no extend more than about an eighth of an inch past the ferule. If it does, the fuel line itself could be pushing into the fuel bowl and interfering with tightening the ferule.
Mike Peters is offline   Reply With Quote
Old 10-04-2020, 11:30 AM   #3
Gary WA
Gary WA's Avatar
Originally Posted by Smitty View Post
Hi All,
Thanks, Steve
cracked ferrel.
www.whidbeymodelaclub.com
Old 10-04-2020, 08:44 PM   #4
Smitty
Smitty's Avatar
Thanks, that seems to have done the trick. Set the fuel pipe 1/8 beyond the ferrel and leak seems to have stopped. Think I knew this and forgot at some point....
Steve
