Old 10-08-2021, 06:59 AM   #1
rockfla
rockfla's Avatar
Default VO meter question
I was checking the volts of two batteries in the shop last night with my multimeter. When I checked one it almost instantly showed 5.7v and started to climbing to 5.8V within about 5 seconds where it seemed to stop. When I checked the second battery it instantly showed about 2.7V and slowly started climbing like filling your car with gas at the gas pump, I stood there for at least a minute (slightly longer) as it would climb all the way to 5.85V is where it seemed to stop!!! It would climb at a slow but steady rate for a bit, then it would climb .01 volt every three or four seconds, THEN at a point start climb at a constant steady rate again THEN slow back down and move .01 volts every 3 - 5 seconds and pick back up again. What's up OR WHY? I could go back to the other battery and BAM, 5.73V and climb again to 5.8 within a few seconds!!!
rockfla is online now   Reply With Quote
Old 10-08-2021, 07:44 AM   #2
34PKUP
34PKUP's Avatar
Default Re: VO meter question
You don't seem to be considering that the meter may be faulty, try another meter.
34PKUP is offline   Reply With Quote
Old 10-08-2021, 07:48 AM   #3
feufeu
feufeu's Avatar
Originally Posted by 34pkup View Post
you don't seem to be considering that the meter may be faulty, try another meter.
+1
feufeu is offline   Reply With Quote
Old 10-08-2021, 09:04 AM   #4
corvette8n
corvette8n's Avatar
I bought a bunch of these analog multimeters at a dollar store in Texas about 15 years ago, gave them all away except one. Rock Auto carry’s them and I’m sure eBay has them also. I keep one in my trunk of my ‘41, these analog meters seem to work better on old 6 volt circuits than the new digital ones.
File Type: jpg 38D44C22-6B2D-460E-BA90-B9FD40ECFA97.jpg (30.2 KB, 20 views)
Old 10-08-2021, 09:32 AM   #5
jayvee34
jayvee34's Avatar
Make sure your battery post are clean. If so, as mentioned above try analog meter.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 10-08-2021, 10:07 AM   #6
51 MERC-CT
51 MERC-CT's Avatar
Acting like the battery in the meter going dead.
Old 10-08-2021, 10:11 AM   #7
deuce_roadster
deuce_roadster's Avatar
What 51 Merc CT said.
Thread Tools
Display Modes
