Old 03-07-2013, 10:04 PM   #1
oldmanandakid
oldmanandakid's Avatar
Default Correct seat attachment
What is the proper seat back attachment for a 30 coupe? My seat is backed by plywood which is screwed to the wood frame between the trunk and passenger compartment. A picture would be helpful if there is one handy.
oldmanandakid is offline   Reply With Quote
Old 04-29-2013, 07:52 AM   #2
Mark from Indy
Mark from Indy's Avatar
Default Re: Correct seat attachment for Coupe back
I also have the same question for my 30 coupe with a trunk - mine is naked in the back. I also have nothing on the sides - sheet metal was used originally attached to the brackets?
Thanks
Mark
Mark from Indy is offline   Reply With Quote
Old 04-29-2013, 08:07 AM   #3
eystein
eystein's Avatar
You need to specify whether your cars are June 1930 or earlier or July 1930 or later.
Up to June 1930 :
- Fixed front seat
- Separate seat back riser
- Angled floor pan in rumble area
- Wide package tray
After June 1930
- Adjustable front seat
- Front seat cushion and backrest mounted to a carriage which moves back/forth on the seat base
- Flat floor pan in rumble area
- Narrow package tray
eystein is offline   Reply With Quote
Old 04-29-2013, 08:44 AM   #4
Mark from Indy
In my case - after June 1930, motor has a May date.
Not sure what the term package tray defines however. Here is a pic of my trunk area as reference.
Its on my to do list to clean up the trunk, and found Old Man and A Kids thread looking for this same thing. The piece of cardboard was just stapled to the back and has since come loose and been removed.
Old 04-29-2013, 09:54 AM   #5
Mark from Indy
Since posting and further digging in the Archives I found this thread that answers the material for the back of the seat.
http://www.fordbarn.com/forum/showth...ighlight=trunk
