Old 02-10-2013, 05:02 PM   #1
JJOHN
Default Running Board recovering
Has anybody seen or heard of running boards being coated with the substance used to coat pickup trucks bedliners? Would it work?
JJOHN is offline   Reply With Quote
Old 02-10-2013, 05:04 PM   #2
jim1932
jim1932's Avatar
Default Re: Running Board recovering
Depends on what type of results you wanted.
jim1932 is offline   Reply With Quote
Old 02-10-2013, 06:13 PM   #3
ford3
that stuff is tough as rubber, but looks terrible , check out some truck beds, you then can see what kind of finish you will have, just plain black, no groves in it like the real rubber made for the running boards, altho if you willing to try you might be able to get the real running board finish if you have an old cover you can use to press the flook into the material before it dries, use light oil or diesel fuel as a release agent, but no matter what it wont look original
ford3 is offline   Reply With Quote
Old 02-10-2013, 06:29 PM   #4
35 coupe
35 coupe's Avatar
I put the bedliner product that advance auto sells on my 50 f1 running boards, does not look bad, but if you get gas on it you need to wash it off quick or it gets soft.
35 coupe is offline   Reply With Quote
Old 02-10-2013, 09:33 PM   #5
okiedokie
okiedokie's Avatar
I had the boards on my 53 f100 coated with Rhino Liner, get lots of good comments. On the other hand I would never consider it for my 40. It certainly beats paint.
okiedokie is offline   Reply With Quote
