03-30-2012, 03:56 PM | #1 |
Timing Gear Backlash on 59AB, what's the max allowable?
What's the max allowable backlash between the aluminum timing gears on a 59AB before they should be replaced? Thanks!
03-30-2012, 04:34 PM | #2 |
Re: Timing Gear Backlash on 59AB, what's the max allowable?
I dont recall a specific measurment for that. but I would say that anything over .015 would my limit .JMO
03-30-2012, 06:28 PM | #3 |
OMO but .015 sounds like a lot to me. ?? ken ct.
03-30-2012, 06:29 PM | #4 |
On the later 8BA type engine it is listed as .002" to .003". Oversize gears used to be available if it was too excessive. If a fellow has the mains align bored you have to check & make sure it doesn't have too little a backlash. You might need some worn gears for that situation. I don't know if they made undersize ones or not.
03-31-2012, 01:55 PM | #5 |
Checking with a dial indicator against a tooth on the crank gear, I can rotate the crankshaft back and forth between the cam gear teeth about 0.012", should I replace them?
04-01-2012, 04:44 AM | #6 |
04-01-2012, 06:48 AM | #7 | |
