Old 09-26-2014, 03:05 AM   #1
Partsfather
Default cast # on model a head
Have a model a ford head with MF1 cast in the top also dated 5 24 48. Any info?
Partsfather
Partsfather is offline   Reply With Quote
Old 09-26-2014, 09:34 AM   #2
CarlG
CarlG's Avatar
Default Re: cast # on model a head
A picture of both sides of the head would be helpful.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-26-2014, 05:51 PM   #3
Larry Seemann
MF stands for Michigan Foundry - a supplier of after market parts. The MF1 I think had a compression ratio of 5.5 or maybe 5.1. The MF2 had a ratio of 6.1 or 6.2. They were high compression heads but I don't remember the ratios exactly. Like the "police heads" they have the heart shaped combustion chamber.
Larry Seemann
Larry Seemann is offline   Reply With Quote
Old 09-27-2014, 09:03 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
With the head on a known good engine, take compression readings. Average all 4 readings and divide the average number by 14.7. The resulting number is an estimate of the compression ratio.
The compression ratio will be higher when the engine is running because there is a dynamic pressure not acting during the compression test. However, the cylinder head's compression ratio is determined with the engine not running.
Bob Bidonde
