Old 10-23-2020, 11:42 AM   #1
PKW181
Default Best spark plug
Hi All,
Just wondering what would be the best spark plug to run in my Flattie?
IT a very early 47 with the stock engine.
Many thanks.
PKW181 is offline   Reply With Quote
Old 10-23-2020, 11:56 AM   #2
ford38v8
ford38v8's Avatar
Default Re: Best spark plug
I've never had a problem with Champion H10C. They're cheap as all get out and get the job done.
Alan
Old 10-23-2020, 04:09 PM   #3
Ford Freak
I've always used Motorcraft 216's in mine . Never had a problem ....... F F
Ford Freak is offline   Reply With Quote
Old 10-23-2020, 04:22 PM   #4
tubman
tubman's Avatar
A lot of people like NGK's, but I've never had a problem with Champions.
It is kind of a pain buying 8 individual "lawn mower plugs" instead of a box of 10 like in the old days. BTW, does anyone have any idea what Champion (and some other plug manufacturers) were thinking when the put them in boxes of 10?
Old 10-23-2020, 04:50 PM   #5
ford38v8
ford38v8's Avatar
By the time you need another set of plugs, you buy another box of ten, just like when you see the bottom of the mayonnaise jar, you chuck it out it and open a fresh one.
Alan
Old 10-23-2020, 06:26 PM   #6
jimalabam
jimalabam's Avatar
Re. your question of best plug? Do you prefer blondes, brunettes, or red heads ???
jimalabam is offline   Reply With Quote
Old 10-23-2020, 06:58 PM   #7
oldford2
oldford2's Avatar
I have used Champion H12's for20 years. My old friend Vic Piano said he would not use them in his lawn mower. Blondes, brunettes, redheads,. My new best favorite is a gray head,
John
oldford2 is offline   Reply With Quote
Old 10-23-2020, 07:15 PM   #8
51504bat
51504bat's Avatar
When I first ordered Champions for my 8ba with EAB heads they came individually packaged as lawn mower plugs. They seemed to run fine but when I rebuilt the engine I changed over to Autolite 216's base on comments here and over on the HAMB. Don't know if there was any real improvement over the Champion's but that's what I'm running for the time being.
Old 10-23-2020, 09:50 PM   #9
Lawson Cox
Lawson Cox's Avatar
One with a nice tan color on the sparking end. LOL
Old 10-23-2020, 11:29 PM   #10
Will D
Will D's Avatar
My car had Autolite 216's when I got it. Using ngk B6L now and never had a problem with either.
Had this happen with a NGK plug once on an alternate make engine. Just finished changing the valve body and this happened upon almost completion. Thank God it came out with a tap on a screw driver and twist as it was 8inch down thru a little hole in the valve body!
Will D is offline   Reply With Quote
Old 10-24-2020, 08:23 AM   #11
flatford8
flatford8's Avatar
I had an electrode pull out of two or three brand new different sets of AL 216’s. I switched to Champ H 10’s......Mark
File Type: jpg 0AEACBD7-5AF5-4345-806B-8E8D3C3F835B.jpg (53.8 KB, 39 views)
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 10-24-2020, 09:13 AM   #12
flat 39
flat 39's Avatar
I used Champion H-10 for years. I switched to NGK and did not notice any difference.
flat 39 is offline   Reply With Quote
Old 10-24-2020, 10:00 AM   #13
MGG
MGG's Avatar
Angry Re: Best spark plug
Good marketing - Buy 4 boxes and then you will have enough for 5 changes!!
MGG is offline   Reply With Quote
Old 10-24-2020, 11:29 AM   #14
Habusailor
Habusailor's Avatar
Sort of like the best oil to use in flathead discussions.
Sent from my SM-T550 using Tapatalk
Habusailor is offline   Reply With Quote
Old 10-24-2020, 11:43 AM   #15
19Fordy
19Fordy's Avatar
I use NGK plugs and just read the info. below on the internet. I always used a dab of anti-seize. Now I find it's not good to do so.
Is it true re: use of anti-seize compound? If so, why? READ BELOW.
"Thread breakage can sometimes involve removing the cylinder head for repair. Metal shell stretch changes the heat rating of the spark plug and can result in serious engine damage caused by pre-ignition. Do not use anti-seize or lubricant on NGK spark plugs. It is completely unnecessary and can be detrimental."
Old 10-24-2020, 04:08 PM   #16
TomT/Williamsburg
TomT/Williamsburg's Avatar
Is this statement for the new, modern day aluminum spark plug holes or is it specifically for our flatties? I think it’s for more modern day stuff ( a CYA-statement perhaps?). If you have used anti-seize all this time and without any negative effects, I would continue to do so. We would need a lot more data to draw any specific conclusions for stock or aftermarket lumi heads, old or new, driving conditions, how far you go, and whatever other variables you come up with ....
TomT/Williamsburg is offline   Reply With Quote
Old 10-24-2020, 04:40 PM   #17
40cpe
40cpe's Avatar
After they mentioned thread breakage and shell stretching, the statement says " Do not use anti-seize OR LUBRICANT on NGK spark plugs." This makes me think they caution against over torquing the plug and resultant damage. Seems they are cautioning against head and/or plug damage in any engine.
Old 10-24-2020, 06:17 PM   #18
Holeshot
Remember that commercial? When your bank says NO. Champion says YES!
But I wouldn't use a Champion spark plug for anything, even a lawn mover.
I have put NGK plugs through some serious torture over the years and they have never let me down.
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament."
Holeshot is offline   Reply With Quote
Old 10-24-2020, 06:35 PM   #19
40cpe
40cpe's Avatar
I'm in the minority here, but I put B6L plugs in my 8ba when I built it 5 years/5000 miles ago. It has started missing above 3000 rpm a while back. After checking the distributor, I began ohming plug wires and the plugs. Some of the spiral wound wires showed open and some of the NGK non resistor plugs read really high. One of the plugs read 38000 ohms and several more in the thousands. I replaced the wires with low resistance spiral wound and plugs with Autolite 216 and now it is happy again. I know they eventually wear out but 5000 miles is a little premature for wires and plugs, I think. The Autolite plugs all read less than 50 ohms resistance.
Old 10-25-2020, 08:13 PM   #20
1oldtimer
1oldtimer's Avatar
I use NGK also, because I got them on sale in bulk (the Studebaker runs the same plug also).
1oldtimer is offline   Reply With Quote
