03-09-2012, 02:20 PM | #1 |
1932 Clutch & Brake pedal shaft
City:
Worcester
State:
MA
I need a 32 to 34 Ford passenger car clutch and brake pedal shaft its about 5&5/16 inches long. I already have the bushings but every place I called says the same thing, that they are all out and don't have a time frame when they will be restocked. Can someone hook me up? I don't want a used one thanx I already have one of those . Send me some pix and PM if you can help
[email protected] |
03-09-2012, 02:50 PM | #2 |
Re: 1932 Clutch & Brake pedal shaft
If you are looking for the part I think you are try a bearing supply company for a shaft and then have it cut to length.
Charlie Stephens |
03-09-2012, 02:58 PM | #3 |
thanx Charlie
[email protected] |
03-09-2012, 03:22 PM | #4 |
I have had success with a piece of 7/8" cold roll bar. It is accurate to size and smooth. Go around to fab shops and beg a piece.
03-09-2012, 03:36 PM | #5 |
Another source might be a shaft from a different year that could be cut to length. Or maybe the shaft that mounts the throw out arm. NOS or NORS would probably beat current off shore manufacture.
Charlie Stephens |
03-09-2012, 03:40 PM | #6 |
[email protected] |
03-09-2012, 09:55 PM | #7 |
I have n.o.s. ones 19.00 Part number B-7506 plus 5.50 postage
03-09-2012, 11:11 PM | #8 |
Excellent Can I see a picture of it ? And where do I send the check I will get it in the mail Tomorrow? I am sending you a PM
Thanx Ghost
[email protected] |
03-10-2012, 06:54 AM | #9 |
Many thanks to Fred from MN for hookin me up with the part I need from South Side Obsolete. Payment is on the way
[email protected] |
