Old 08-09-2020, 07:44 PM   #1
keyswitch1
Default model a does not start
I have gas in the tank and the car does turn over but does not start. What is the sequence to get it running? Thank you in advance !!
keyswitch1 is offline   Reply With Quote
Old 08-09-2020, 09:12 PM   #2
McMimmcs
McMimmcs's Avatar
Default Re: model a does not start
The first thing to check is to see if the fuel valve is turned on.
McMimmcs is offline   Reply With Quote
Old 08-10-2020, 07:29 AM   #3
chap52
chap52's Avatar
All of you who have forgotten to open the fuel valve when starting raise your hand... Yep, that is what I would check first. Then follow BruceW1's advice. "Enjoy the adventure"... Chap
chap52 is offline   Reply With Quote
Old 08-10-2020, 09:55 AM   #4
Scotts216
I recently tried to start a 31 that had sat for years and had similar issue. I had gas to the carb, but it would not start. I took the carburetor apart and cleaned it and found that the main jet was clogged with old fuel gunk. Once clean, it started. But now I have a starter problem. Good luck.
Scotts216 is offline   Reply With Quote
Old 08-10-2020, 11:28 AM   #5
Patrick L.
Patrick L.'s Avatar
Fuel on
left lever up
right lever down a few clicks
key on
clutch in or in neutral
push starter switch while pulling choke rod for about 2 revolutions
engine start, choke in, left lever down to half, right lever up
If that doesn't work,
check for spark
check for fuel
let us know
Old 08-10-2020, 02:12 PM   #6
30 Closed Cab PU
If lights/horn are also not working, check the starter mounted fuse if you have one. With that mod everything is fused, except the starter.
My spark check
When cranking with the key/ignition on , most A's ammeters wiggle slightly from the points opening/closing. Early cars that have not been modified will not wiggle. The wiggle tells you the primary circuit (battery, ignition switch, points, points ground, and coil primary are OK. If that is OK remove a lead from a spark plug and space it 1/8 inch from the spark plug terminal. With the Ignition on hit the starter, can do this using the starter rod in the motor bay, and you should see a nice blue spark every 2 revs of the motor.
30 Closed Cab PU is offline   Reply With Quote
Old 08-10-2020, 05:02 PM   #7
daveymc29
daveymc29's Avatar
Just had that, see above. It was a nearly new condenser. Old one in parts bits made it come back to life.
daveymc29 is offline   Reply With Quote
Old 08-10-2020, 07:33 PM   #8
1955cj5
1955cj5's Avatar
Be sure to clean the contacts on the points.
Use a tungsten point file or emery cloth.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
