Old 03-08-2013, 07:45 PM   #1
milehigh40
Default 40 ford truck
i am removing the spare tire and mounting bracket from the right rear fender of my 40 ford truck. i am looking for a molded patch that can be welded to cover the indentation. any know of such a panel and who can i contact/
mile high 40
milehigh40 is offline   Reply With Quote
Old 03-08-2013, 08:31 PM   #2
malpais
malpais's Avatar
Default Re: 40 ford truck
I've have not seen a patch panel like like that, but if it exists someone here will know about it. I would think you would need to cut one out of a "donor" fender. Are you on the Front Range? I might have something.
Gordon
Don't mind learning from my mistakes. Just wish I didn't learn EVERYTHING from my mistakes..
malpais is offline   Reply With Quote
Old 03-08-2013, 08:36 PM   #3
swoopNZ
MEMBER EMERITUS
Early VW fender will have a close shape.
swoopNZ is offline   Reply With Quote
Old 03-08-2013, 10:36 PM   #4
TJ
TJ's Avatar
Cut the indentation out and flip it over. I suspect it has the same curve.
Old 03-09-2013, 08:38 AM   #5
Wingfield
Wingfield's Avatar
I used a porta power and pushed mine out. It isn't that deep, easier than cutting and welding.
Wingfield is offline   Reply With Quote
Old 03-09-2013, 03:48 PM   #6
Roger/Sacramento
Roger/Sacramento's Avatar
My body guy pounded out a patch panel on the concrete floor and welded it on to the fender over the dimple. Looks perfect.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 03-09-2013, 05:01 PM   #7
40fordpu
40fordpu's Avatar
Does anyone have pics of what we are talking about??
40fordpu is offline   Reply With Quote
Old 03-09-2013, 08:11 PM   #8
malpais
malpais's Avatar
See attached photo. I thought maybe I have one without the dimple.
Gordon
Old 03-09-2013, 08:53 PM   #9
quickchange34
quickchange34's Avatar
That was done with a die. It has a reversed crown and that means its been streched big time. Yes you can work it up but you are going to have alot of srinking to do to get the excess metal out. If you plan to metal finish it.
quickchange34 is offline   Reply With Quote
Old 03-11-2013, 06:05 AM   #10
Wingfield
Wingfield's Avatar
Just stating what I did with mine. I must admit I did use a skim coat of filler.
Old 03-11-2013, 09:00 AM   #11
TomT/Williamsburg
TomT/Williamsburg's Avatar
Any fender with a similar curvature will provide a good patch.
I just went to a metal shaping class - just take the shape from the other fender and flip it around. Here's how: place/tape saran wrap on the driver fender in the area of the patch needed (for ease of tape removal), tightly criss/cross tape over the area with cloth reinforced tape (packing tape), now remove from the fender. Go over to your pass fender, turn it from top to bottom to bottom to top, place over the indented area, make your outline of the opening and trim. Now you have an exact shape of the patch you need. It worked really, really slick - for kicks, take the patch from an old C---- fender - it will put a smile on your face while doing it!
TomT/Williamsburg is offline   Reply With Quote
Old 03-11-2013, 12:41 PM   #12
Hamtown Al
Hamtown Al's Avatar
I hammer and dollyed mine until it was gone. Little bondo and it was done!
Patience is the key. Be sure to rest now and then!
Al
36 Fords Rule! Visit at www.36fords.com.
Hamtown Al is offline   Reply With Quote
Old 03-11-2013, 07:12 PM   #13
Krylon32
Years ago I built a 40 PU for a customer and my body shop cut the spot out and rolled a patch on the English wheel and hammer welded it in. Couldn't tell it front or rear. Also If I remember right we had to do something to the running board???
Krylon32 is offline   Reply With Quote
Old 03-11-2013, 07:24 PM   #14
Roger/Sacramento
The running board has some missing rib impressions that I welded up with half round stock.....not that difficult. It shows good now because I had the running boards coated with professional bed liner. I highly recommend that because I don't have to keep people off of the paint. Every time my neighbor comes over he puts his foot on either the bumper or running board.
Old 03-11-2013, 08:34 PM   #15
skidmarks
skidmarks's Avatar
the easy way is use a 42 -47 pu fender which has no dimple and change the bottom edge were it bolts to the running board from a 38-41 fender. less welding and smaller area to finish. with little to no bondo
skidmarks is offline   Reply With Quote
Old 03-11-2013, 08:46 PM   #16
Ken Crans
Ken Crans's Avatar
Isn't their different widths between the 40/41 and the 42-47? I should of compared them when i had the two sitting next to each other.
Ken Crans is offline   Reply With Quote
Old 03-11-2013, 09:30 PM   #17
skidmarks
skidmarks's Avatar
the width of the head board and tail gate. not the fenders. difference in the fenders is were it bolts to the running board, 42-47 doesnt have the dimple that is mentioned above and 42-47 doesnt have the hole for the gas fill pipe.
3/4 & 1 ton fenders are bigger
