06-17-2017, 12:21 AM | #41 |
Re: still overheating
Do they still make a cheap test for hydrocarbons in the radiator? Maybe at a place like Pep Boys. That would confirm a head gasket leak.
Charlie Stephens |
06-17-2017, 02:30 AM | #42 |
At my Tudor it was a cracked cylinder head, at heavy load uphills or high speed the combustion gases went into the cooling system, pressing out the water thru the filling neck of the radiator.
Best regards Chris 1930 Ford A Std. Tudor |
06-17-2017, 09:24 AM | #43 |
Also as someone suggested way back, have you done a compression check to see if the head gasket is blown? Seems to me when you posted before you were going thru the same thing, drive the car and add water after each drive and was told the same thing, the water only need to cover the top plate in the radiator by 1 inch or so. After the water level in the radiator reaches it's running level, this is where it wants to be, adding more is not going to help except watering the asphalt.
06-17-2017, 10:46 AM | #44 |
You can't overfill the radiator. the water level will adjust with the excess coming out the overflow pipe. Don't clog the pipe it's there for a reason. Fix the problem. Do you have a thermostat? If so take it out it could be restricting flow. As was mentioned check your timing. Use the method on a barnyard.com. Improper timing can quickly overheat your engine
06-17-2017, 11:33 AM | #45 |
Hidden deeply in your first post and referred to often above:
"I have replaced the radiator"; and, "Still over heating after about 30 minutes". In accordance with some of the above hints, ever think if you now tried 379 new radiators, could the: "Still over heating after about 30 minutes" scenario still occur. Yes or no? |
06-17-2017, 09:54 PM | #46 |
Reverse flush the radiator from the bottom to the top, do not use full pressure or you will damage your new possession. When you are done reinstall the hoses, buy 3 gallons of white vinegar and fill your system, do not over fill, you do not want vinegar on your paint so carry a damp rag with you while you are driving. Test your hoses for leaks, then take your car out for a drive and build up some heat, you may have solved your over heating problem or not at this stage. Leave the vinegar in for a week and drive it as often as you can, watch your temp. you really need an infrared temp meter to monitor things accurately, borrow or buy one. Drain it all out after a week do the flush thing again, add 50-50 antifreeze and road test again, hopefully you will have solved your over heating problem. I have had great success by adding a thermostat, we had one of our cars out today in 90+ deg. weather with a 160 thermostat and it ran all day long at 150 deg. I don't think you said you had a dash mounted gauge, if you ever do don't trust it till you verify it with a infrared temp meter, one of my cars has a gauge that reads 45 degs. high. No I didn't check before I did all of the above. Let us know when you succeed and what you did to whip it!
Steve - Santa Rosa |
Thread Tools | |
Display Modes | |
