Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 02-06-2021, 03:56 PM   #1
Frankyboy
Default 324-371 Olds
Ok , so here is the question, I have a 324 Olds Rocket motor, missing the lower bell housing. I have a new aftermarket flywheel 176 tooth. I’m gonna use a offy adapter to a 3 speed Ford top loader. This is the question , I’ve been offered a lower bell housing off a 371 ! Will it fit ????? This is it . Thanks in advance
chops diner wrightsboro nc menu
Frankyboy is offline   Reply With Quote
Old 02-06-2021, 04:57 PM   #2
42merc
42merc's Avatar
Default Re: 324-371 Olds
Yes, it will fit.
42merc is offline   Reply With Quote
Old 02-06-2021, 05:19 PM   #3
Frankyboy
Cheers for that , I take it , I’ll just need to get the correct starter ��
Old 02-06-2021, 07:11 PM   #4
redmodelt
redmodelt's Avatar
For questions about Ford cars ask on the proper forum, for hot rod cars with non Ford engines such as this try; https://www.jalopyjournal.com/ This section is for issues with the use of the site not car questions, the editors don't answer car questions. Good luck with your project.
