Old 05-02-2018, 09:54 AM   #1
Jiggers
Default Passenger Side Peep Mirror
Does anyone know of a source of a peep mirror that will work on the passenger side of a 47? All the one's I have seen that say they are for the RH side, the arms are not curved down far enough to be useful.
Jiggers is offline   Reply With Quote
Old 05-02-2018, 10:20 AM   #2
50fordcoupeman
50fordcoupeman's Avatar
Default Re: Passenger Side Peep Mirror
Passenger side is the right hand side..........does that help?
50fordcoupeman is offline   Reply With Quote
Old 05-02-2018, 10:43 AM   #3
4dFord/SC
4dFord/SC's Avatar
I use a blind spot mirror stuck on the wind wing. It's not ideal, but it helps.
4dFord/SC is offline   Reply With Quote
Old 05-02-2018, 11:14 AM   #4
40cpe
40cpe's Avatar
I have two of these on my '38, convex on both sides of the car. There is enough convex to give a wider field of view, but not enough to be "fisheye". The mirror head swivel is offset to allow more drop if needed. The head is reversed on the arm for left or right. These appear to be a United Pacific product available on Amazon.
Old 05-02-2018, 11:42 AM   #5
drolston
drolston's Avatar
I used straight arm mirrors mounted on the front edge of both doors. The mirror rotates on the arm to work on either side. Stuck a 4" convex on the passenger side. Works great.
Old 05-02-2018, 11:47 AM   #6
scicala
scicala's Avatar
Depends what country your in.
Sal
scicala is offline   Reply With Quote
Old 05-02-2018, 12:08 PM   #7
RKS.PA
RKS.PA's Avatar
The right hand "original" on my '47 was listed in the Ford Book as being purely for decoration and "balance" for the one on the driver's side. I have a convertible and with the top up, I'm totally blind making a lane change from left to right.
I found a wind wing mirror for the Model T in Mac's, mounted on the right wind wing and noted by 40dFord and put a wide angle mirror on top of the regular mirror that came with it. Yes, I need to keep the wind wing open a little....a new form of mirror adjustment.....and now I have no blind spot!!! It worked for me!!
RKS.PA is offline   Reply With Quote
Old 05-02-2018, 01:27 PM   #8
oldskool
oldskool's Avatar
I own 3 fat fender cars and no mirror has ever worked for me on the pass side.
oldskool is offline   Reply With Quote
Old 05-02-2018, 03:48 PM   #9
bobH
I made a bracket (polished stainless) that clips on the edge of the wind wing, and straddles the top pivot. I put a stick-on convex mirror on it. No more blind spot.
And yes, to RKS comment above... total blind spot on right side, mine being a 47 convert.
bobH is offline   Reply With Quote
Old 05-03-2018, 10:05 PM   #10
fordor41
fordor41's Avatar
pretty much useless on the P.S. they look cool!!
fordor41 is offline   Reply With Quote
