Old 02-28-2016, 06:12 PM   #1
fh
Default '35 Fuel Sensor
Can the fuel sending unit be accessed without removing the tank on a 1935 coupe? Would like to know before removing rumble seat lid.
fh is offline   Reply With Quote
Old 02-28-2016, 06:23 PM   #2
Brian
Brian's Avatar
Default Re: '35 Fuel Sensor
yes, there is a cover, secured with one screw in the floor above tank
Old 02-28-2016, 09:07 PM   #3
fh
Thanks.
Old 02-28-2016, 09:40 PM   #4
my mostly 36 coupe
my mostly 36 coupe's Avatar
It might sound a little crazy but if you open the rumble seat, remove the back cushion, close the rumble seat then crawl inside the car with a flashlight, you will have all the room you need to remove the fuel sensor and inspect the tank etc. Some folks have also said to simply open and hold the rumble lid in the right position to get at the cover plate screw (that Brian had just mentioned), then you have access to the fuel sender screws. Only my opinion but you don't want to remove and re-align the rumble seat unless necessary. Tom
my mostly 36 coupe is offline   Reply With Quote
Old 02-29-2016, 01:05 AM   #5
fh
Thanks Tom, I'll give that a shot. I do know that my old 6' 5" frame gets a little stove up crawling around in cramped quarters.
