Old 01-13-2022, 01:38 PM   #1
Birchwood
Default Transmission flush
I have a 30 tudor that has been setting for a good while and the transmission is extremely tight, Clutch is stiff. Is there a recommended way to flush the transmission to loosen it up.
Thanks
Birchwood is offline   Reply With Quote
Old 01-13-2022, 03:34 PM   #2
Oldgearz
Default Re: Transmission flush
I'd just drain the tranny and add new 600w oil. Clutch is separate from the tranny and therefore anything you do to the tranny really won't affect the clutch (assuming it is a working tranny). You might take up the floor board and remove inspection plate and have a look at throw-out bearing and springs. Lube the shaft the throw-out bearing slides on as needed.
Oldgearz is offline   Reply With Quote
Old 01-13-2022, 03:50 PM   #3
gdmn852
gdmn852's Avatar
Hello,you may also want to check the play in clutch and brake pedals and also the clutch linkage usually a lot of wear in them causing the clutch not to release completely.Some models also have grease fittings on bell housing for the clutch shaft that operates the throw out bearing.
gdmn852 is offline   Reply With Quote
Old 01-13-2022, 07:06 PM   #4
Big hammer
Drain and add automatic transmission fluid turn by hand with rearend off the ground drain and add 600w or Mikes Afordable 1500w or heavy gear oil
get a bigger hammer tap done
Old 01-14-2022, 06:18 AM   #5
Synchro909
Synchro909's Avatar
I do pretty much as Big Hammer said but a Run the transmission with the wheels off the ground (ATF in there). I run it for a minute or so, then drain and refill so long as what comes out looks sorta OK. With no load on the gears, ATF gives plenty of lubrication and is light enough to get the goo moving.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 01-14-2022, 07:11 AM   #6
Birchwood
Thanks for the advice I will try it this weekend your help is appreciated.
Old 01-14-2022, 08:08 AM   #7
Patrick L.
Patrick L.'s Avatar
Agree with a flushing with ATF and the way to do it. Then I prefer 140 or 250 oil.
Old 01-14-2022, 08:38 AM   #8
Kurt in NJ
Kurt in NJ's Avatar
There's a grease fitting on clutch bearing hub , grease there could be dried up making clutch action stiff
