Old 09-09-2021, 01:44 PM   #1
pjdeb
pjdeb's Avatar
Default MMO: How much is a little?
Model A has been sitting for 9 months. Want to put a little MMO in cylinders when I have plugs out for clean & checking the gap.
How much is a little? Oz.? Table spoon?
Is it best to let it sit in there a day or two?
Thanks.
pjdeb is offline   Reply With Quote
Old 09-09-2021, 02:14 PM   #2
Jeff/Illinois
Jeff/Illinois's Avatar
Default Re: MMO: How much is a little?
I'd just 'glug' some in each cylinder and not worry about measuring it.
Good stuff I use it regularly always in my gasoline.
Jeff/Illinois is offline   Reply With Quote
Old 09-09-2021, 02:29 PM   #3
Patrick L.
Patrick L.'s Avatar
A few squirts of oil into each hole will do. Spin the engine over to distribute before installing the plugs.
Old 09-09-2021, 02:31 PM   #4
ronn
I put more then a "little" in my gas tank 2 yrs ago and now seems gooey!!!!!!!!
gooey gas.........
Old 09-09-2021, 02:38 PM   #5
Cape Codder
Cape Codder's Avatar
pjdeb - Maybe an oz. in each cylinder but won't hurt if a little more!
Container says ADD 4 oz. MMO to 10 Gals. of gas, is what I do when filling up!
Cape Codder is offline   Reply With Quote
Old 09-09-2021, 02:51 PM   #6
Oldgearz
I use 2 oz. per 5 gallons of gas in tank. If putting in the sparkie holes, put in at least 1/2 table spoon and let set an hour or so so it runs through the rings as best it can. It's gonna smoke and sputter on start up....just keep running till rings seal and smoke stops.
Oldgearz is offline   Reply With Quote
Old 09-10-2021, 10:53 AM   #7
katy
katy's Avatar
https://www.wonderopolis.org/wonder/...than-a-smidgen
Old 09-10-2021, 03:31 PM   #8
wrndln
I have never used MMO, but I might try it. Is there just one kind of MMO? Is the picture below the stuff used in the oil and gas discussed here? BTW, does MMO get old?
Old 09-10-2021, 04:19 PM   #9
Jeff/Illinois
As far as I know, it doesn't have a shelf life like Sta-Bil gas treatment does. Once you break the seal on Sta-Bil I believe you have about 12 months to use it up.
Someone correct me if I'm wrong but as long as you keep the lid on snug you're good to go. To me, it is more of a very refined oil on the order of ATF. Plus it smells good!
I buy a gallon jug of MMO at WalMart or Farm and Fleet and fill a quart bottle of MMO when it gets empty, to use that to pour into the gas tank. They have handy measurement markings on the side.
Old 09-10-2021, 06:08 PM   #10
burner31
burner31's Avatar
A little in the tank and a little in the driver...but then again I'm Irish.
(Do not try this at home)
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 09-11-2021, 06:25 AM   #11
Big hammer
One kind? I don't know, stuff in picture IS used in gas or oil, does MMO get old ? Not if your using it ! I have or had 2 gallons that I had for a long time,refilled into their small bottles .
get a bigger hammer tap done
Old 09-11-2021, 03:15 PM   #12
rotorwrench
rotorwrench's Avatar
Whatever you put in the cylinders will generally find it's way through the rings by the next morning. I wouldn't put more than 2 fluid oz per cylinder myself but any amount won't hurt anything as long as it doesn't liquid lock when turning the hand crank.
