01-20-2022, 10:09 PM | #1 |
Universal Joint Cover
Just having a moment......
I have forgotten what part of the Universal Joint Cover goes on the top when reassembling. Left or right? Can someone remind me please? Thanks |
01-20-2022, 10:48 PM | #2 |
Re: Universal Joint Cover
the one on the left goes on top. the cast center finger hooks (sets above)on top of the cross member.
01-20-2022, 10:51 PM | #3 |
Many thanks!!
01-20-2022, 11:05 PM | #4 |
I'm guessing this is an early one?
01-20-2022, 11:41 PM | #5 |
JohninKuranda wants to know what part of the Universal Joint Cover goes on the top when reassembling. Answer - The one on the left goes on top. the cast center finger hooks (sets above)on top of the cross member - jlgco14. |
01-21-2022, 04:51 AM | #6 |
"The more things change, the more they stay the same." |
01-22-2022, 01:28 PM | #7 |
another thing to keep in mind is there are 2 different transmission rear bearing retainers with different bolt patterns, make sure they match up.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
01-22-2022, 05:11 PM | #8 |
U-Joint Cover Gasket
I have been trying to figure out a better solution to the rectangular cork gasket that leaks at the back of the transmission in the clam shell that covers the U-Joint. I found a rubber gasket that is 5/16 x 5/16 that is used for industrail hose couplings. It is only 2 inches in side diameter so it does have to be cut at the joint between the top and bottom of the clam shell. They do have a 4 inch gasket, but it is 5/16 by 3/8 and that makes the fit too tight and it will not squish down any. They also told me that they use E6800 sealer for areas like the joint between the clam shells. We put one together and clamped on the end of a drive shaft and, with a little grease, it does feel really good. I have not yet installed my motor and transmission to be sure that this solution will work, but it sure looks better than the cork solution. The number on the gasket is 20YST BUNA 5/16 gasket, $1.90 each. These gaskets are used for quick coupling industrial hoses
Steve in Denver |
01-23-2022, 09:54 AM | #9 |
on the old style u-joint/ball cover there is an oiling gallery along the top edge of the old style flanges.
if it were i, unless the cross shaft is being used, i would seal those inside gallery's incase there is seepage. but i have always change that housing for the newer style.
01-23-2022, 10:23 AM | #10 |
Used through Oct/Nov of '28.
No one wants advice - only corroboration. -John Steinbeck |
01-23-2022, 10:40 AM | #11 |
How about a big O-ring? They come in various thicknesses and diameters.
01-23-2022, 10:55 AM | #12 |
I have looked, it needs to be 3 3/4 outside dimension and 5/16 thick. I have checked with two industrial pipe places and the square one is the only one I have found so far. See if you can find anything.
Steve in Denver |
01-23-2022, 11:45 AM | #13 |
Try an oilfield supply place.
01-23-2022, 11:48 AM | #14 |
McMaster-Carr
01-24-2022, 01:46 PM | #15 |
there are people who make and sell o ring style gaskets. I think it is an industrial
Bulk material and the ends are glued together. they are sold on eBay,or were. John
Welcome each day |
01-24-2022, 04:27 PM | #16 |
Folks, here is an o-ring seal kit for the u-joint/torque tube that works. It's ebay item number 251255228584..............
AL in NY |
01-24-2022, 07:51 PM | #17 |
Great, I just ordered 3. Thanks
Steve in Denver |
01-25-2022, 09:21 AM | #18 |
The original seal there was likely Felt originally. I'm not sure why they went to cork. The later Fords used felt up to 1948 but the cork is an ever present replacement. It's basically just a dust seal.
01-25-2022, 09:55 AM | #19 |
My ball cap does not leak. I installed it with original gaskets and cork seal.
01-25-2022, 01:36 PM | #20 |
Either there is something wrong with it or it must be dry!
Steve in Denver |
